07-27-2010, 10:51 AM | #1 |
Rock Stacker Join Date: Apr 2010 Location: El Paso
| dig servo prediciment
Getting my dig setup that i just recently bought from the classifieds (thanks K.O.M!) and I'm wondering if I am doing something wrong or if its something else. (I am an electronics idiot) Here is the problem: Plug the throttle in - no problem Plug the steering in - no ploblem Plug the dig servo in - no problem with the switch on the radio, but when i steer the dig servo moves 1/8" in the direction i am turning. This happens in any position on the dig. I have made sure wires dont touch, swapped dig/steering on rx. Here are the electronics i have. Novak rooster Novak 55 turn Dx3 tx SR3000 rx (the antenna came out) hitec 5645 steering servo futaba s3003 dig servo Thanks for any help |
07-27-2010, 11:56 AM | #2 | |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Narly1 | |
07-27-2010, 01:31 PM | #3 |
Checked the tx and it is in 3P mode????
07-27-2010, 03:17 PM | #4 |
Sorry, I was wrong...the DX3 does not have mixing. I retract my statement now that I have a manual in front of me. Have you tried completely resetting the radio and starting from scratch? 1. Turn transmitter on while holding down both the MODE and CHANNEL keys at the same time. 2. Use the MODE key to scroll through to the CLR (Data Reset) screen. 3. Press both the INCREASE and DECREASE keys at the same time to clear ALL settings. 4. Turn transmitter off and then on again and start reprogramming all your settings. Narly1 |
07-27-2010, 04:31 PM | #5 |
HA! fixed. thank you thank you thank you. The resetting the tx woked. now i just have to set the EPA's Thank you Narly1 |
07-27-2010, 05:19 PM | #6 |
Glad to help. Now go have some fun with your rig!! Narly1 |
