Thread: servo problem
Old 07-30-2010, 02:41 AM   #1
Default servo problem
I've just installed a new airtronics 94780m servo on my axial. The thing is that when the servo is turned to the right, the horn will like studder or kick back rapidly or kinda like shake. It turns to the left fine. But when I take off the steering link the servo turns fine. Then I'll use the fingers to drag down the servo while trying to turn it to the right, it'll do the same thing. I've never seen anything like this before with all of the hitecs/jr's that I've used in the pass. Any ideas?
heeper40 is offline   Reply With Quote
Old 07-30-2010, 05:57 AM   #2
Sounds like it's defective, try another servo
motorman is offline   Reply With Quote
Old 07-30-2010, 07:07 AM   #3
Are you running a BEC and it so, whats the voltage set at? Sounds like its not getting enough power.
redbaron is offline   Reply With Quote
