08-02-2010, 11:11 PM | #1 |
Newbie Join Date: Jun 2010 Location: sydney, Australia
| Problem with dx3r + dig pls help have searched!
Hi all Sorry guys i have searched but no answer to my problem. I'm having problems with my dx3r and dig, my servo keeps going back to neutral position when I let go I have set the middle button on the grip to aux 3 p which is cool I have adjusted the endpoints and everything works sweet but the big problem is I have to hold the button ether position to engage the dig or 4wd the servo keeps going back to neutral. I can't work it out and it's quiet annoying specially when I push the button left or right it keeps beeping I know there is a better way than this can anyone help? Sorry guys I just can't find a thread with my problem and my servo is a 645mg Thanks all Donny |
08-02-2010, 11:56 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
Im not sure i understand. You say you have to hold the dig switch for it to engage, and when you move your finger it goes back to neutral? Also, what kind of dig?
08-03-2010, 12:13 AM | #3 |
Hey mojo It's the junfac dig for the gmade r1, Sorry if I was unclear before. I have to hold the button down to engage 4wd and when I let go it goes back to 2wd and rear free wheels. same for the rear lockout, if I let go it will go back to freewheeling basicly my servo won't hold the position I have set on the tx. Is it my servo or do I need to set something else on my tx thanks |
08-03-2010, 03:18 AM | #4 |
Try switching the 3p button to another one like C and see if it works. It may be a bad switch. I think i asked before if i could set it up like that, but backwards where i hold the button for dig and let go for 4wd. And i got a bunch of no's.
08-03-2010, 10:49 AM | #5 |
thanks man i will try after work today hope this works thanks again!
08-03-2010, 11:58 AM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
I tried replicating the problem with my DX3r and couldnt get it to have the same issue as you. Like fattymojo said it sounds like a buggered switch. Something I do when I play around with servos on my radio is to refer to the monitor as this shows in realtime what the servos are doing. If you are having an issue with the switch it'll show up on the monitor. |
08-03-2010, 12:29 PM | #7 |
Thanks Roo Dam that does not sound to good for me my radio is still pretty new dam! so what do i look out for in monitor will the numbers jump around and run smooth. sorry for the stupid q roo do you think it might be a servo problem as well by the way what are you doing up at this time? Thanks Donny |
08-04-2010, 11:38 AM | #8 |
i worked it out! sorry about the thread guys i set D as the 3p and i had c as AUX LIN thats why they servo keeps moving back to the neutral position i inhiberted that one C now and its works perfectly Thanks for the help guys |
