08-09-2010, 07:50 AM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Vienna, Austria
| [solved] futaba 2pl-2.4g control distance problems
hi i own a futaba 2pl-2.4g with 2 receivers, and got a strange problem. after some time with no problems at all, there seems to be some communication problem between the remote control and the receiver - starting at a distance of 3(!!)meters (=10feet). the behaviour is as follows: motor stops at full throttle, and then comes back within tenth of a second, leading to a stuttering motion. on-off-on-off-on-off, until i get back in the 3m range again. this is not ok - is it? what can i do. i heard moving receiver and motor as far away from each other would help. but i can't move it further away from each other than it's installed atm. (see picture). any advice? what should i do? ps. battery is fully loaded of course. both of them ;) Last edited by izeman; 08-09-2010 at 08:29 AM. Reason: problem solved |
08-09-2010, 08:28 AM | #2 |
sometimes things are strange. after struggeling with that issue for weeks, i posted that question. than i thought: i could open the remote and have a look. and guess what? the little hf-antenna connector came loose. i plugged it in/on. and secured it with some hot glue - just in case. everything's working great again ;) |
08-09-2010, 08:34 AM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Magic! Glad ya found it! |
