Thread: Motor problem
Old 08-17-2010, 04:31 PM   #1
Default Motor problem
I have a new problem with the front motor in my crawler. It's the same one that had a broken brush but I don't know if the two problems are related. It was working fine the day before but yesterday I went out and the front axle wouldn't turn until I spun the tire by hand to get it started. It would go fine until I stopped, then the same thing. I thought it was the front axle binding but when I removed the motor it would still do the same thing, not spin until I bumped the pinion to get it started. It's an almost new JPH 31T crawler motor, I haven't taken it apart yet but I wouldn't know what to look for anyway.
Any ideas.....?
AdverseCity is offline   Reply With Quote
Old 08-17-2010, 04:43 PM   #2
DId you endup replacing the brush? Or just trying to make the broken one work?
Later EddieO
EddieO is offline   Reply With Quote
Old 08-17-2010, 04:48 PM   #3
MODERATOR™
EeePee's Avatar
I told ya don't run that motor.
EeePee is offline   Reply With Quote
Old 08-17-2010, 06:18 PM   #4
I didn't run it after I knew it was broken and only briefly for testing before that, maybe a couple minutes on the workbench and grass. I did replace the brush with a brand new Infinity one with help from a guy who knows motors. We'll open it up later this week, just trying to get an idea of what it might be.
Old 10-31-2010, 12:27 AM   #5
im having this problem,any thought???as soon as i give it a little bump by hand it will start spinning
jeepron is offline   Reply With Quote
Old 10-31-2010, 05:50 AM   #6
stuck spring?
JesterSpec is offline   Reply With Quote
Old 10-31-2010, 07:00 AM   #7
no, i read up on lastnight, sounds like a shorted armature,gonna have to call fantom
Old 10-31-2010, 09:42 AM   #8
Might have a hung brush/spring. Also check the brush hood alignment. If its warped, as the brush wears it will no longer make good contact with the comm.
out4crawlin is offline   Reply With Quote
Old 10-31-2010, 09:48 AM   #9
its definetly the arm., i switched it with the other one i have and it worked fine
Old 10-31-2010, 11:43 AM   #10
MODERATOR™
EeePee's Avatar
Might not be shorted, if it's older and hasn't ever been taken care of, or cleaned up and cut, they will get so out of true, or develop flat spots that the brush doesn't make good contact. You give it a little push and it overcomes that flat spot.
Old 10-31-2010, 11:48 AM   #11
You can't adjust the hood aligntment on a Checkpoint based motor......and there is really no way to throw it out of whack, without literally destroying the endbell....
Later EddieO
Old 10-31-2010, 11:54 AM   #12
the motor is practicly new
Old 10-31-2010, 03:07 PM   #13
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Sounds like you have a dead phase on the motor. Easy test, get a multimeter and see if there is continuty on all segments.
JohnRobHolmes is offline   Reply With Quote
Old 10-31-2010, 03:26 PM   #14
not really a motor guy,whats the segments??
