08-19-2010, 03:28 AM | #1 |
Newbie Join Date: Aug 2010 Location: surprise
| motor ?s
I want to keep the wheel speed I have but want a little more toque I have rooster esc novak 55 2s 1300 mah lipo 20 t pinion 87 t ring gear any suggestions .
08-19-2010, 03:46 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Possibly a 45t and drop a tooth or two on the pinion? A hand wound motor would perform better also. Or go 3s and turn down your thr epa if you want to keep your wheelspeed down? The axial I have setup for my brother is on 3s with a 55t and will snap the outdrives off...but it needs more wheelspeed. Going to try a 45t in it next. I'm also in surprise if you need any other help or want to join us in gtg's |
08-19-2010, 05:01 AM | #3 |
I say 3s and 15t pinion. It would be a great compromise and you would gain both torque and power.
08-19-2010, 07:47 AM | #4 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
So sad, the rooster doesn't support 3s. |
08-19-2010, 08:17 AM | #5 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
I'll back JRH on this one. If your Rooster is no longer under warranty, go 3S. It can handle it. Don't forget to gear down though. Cheers. |
08-19-2010, 09:43 AM | #6 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
08-19-2010, 10:09 AM | #7 |
| If you are happy with your setup but just want more torque a Holmes Hobbies Handwound 55T will be a noticable improvement over that machine wound Novak motor.
