08-19-2010, 06:04 PM | #1 |
Newbie Join Date: Mar 2010 Location: bothell
| Help crawler wont move!!!
my rc crawler wont move. the servos work. but motor doesnt spin. i just tried reprograming my tekin fxr. i got and axial ax10 with futap 3pm fm remote. it worked fine until i did this.
08-19-2010, 06:08 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
I'm going to go with programming problem. 1#. Make sure the little cap is still installed (will make it go poof) 2#. Try reversing the throttle (or try programming it backwards) 3#. GET a HOTWIRE if you dont already (I've got a fxr...so much better now) |
08-19-2010, 06:10 PM | #3 |
that cap is still there. it wont move if i pull reverse or forward on it. that how this started i tried to program it with hotwire. it wont even do the random twitch with the controller off.
08-19-2010, 06:13 PM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Have any cutoffs set on the esc? Have you tried a freshly charged pack?
08-19-2010, 06:17 PM | #5 |
no cuttoffs. running a 6 cell venom nimh
08-19-2010, 06:19 PM | #6 |
When programming it and you are supposed to press reverse press forward and when you are supposed to pull forward press reverse.......no what I mean. Thats happened to me before. Also make sure trims are set to zero while doing it.
08-19-2010, 06:21 PM | #7 |
i will try that now.
08-19-2010, 06:26 PM | #8 |
i put the esc on the older update and it works now.
