08-20-2010, 08:08 AM | #1 |
| DX3R Work With Older DSM1 RX's?
Thinking of picking up a pistol radio and have a couple in mind with one of them being the DX3R. I already have the DX6 and like 4 SR6000 RX's and was wondering if the DSM2 DX3R will work with the SR6000's (obviously with less functionality)?? I only ask because if they will work it would steer me more in the direction of the DX3R....but if not, I might just get the 4PK. |
08-20-2010, 09:12 AM | #2 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
I don't think the older air and land stuff are compatible. Thought the air rx only worked with air transmitters and the land rx only work with land transmitters.
08-20-2010, 09:18 AM | #3 |
| I believe the Rx he is asking about is a Surface Receiver...however, I am not sure if it will work with the DX3R. The best way to find out would be to contact Spektrum/Horizon....
08-20-2010, 09:30 AM | #4 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
The SR6000 is a 6 channel parkflyer regular dsm air receiver. It will not work with surface dsm radios. I'm not a spekturm guy but remember something about them being backwards compatible. But I'm pretty sure they are not air/land interchangeable.
08-20-2010, 10:40 AM | #5 |
Ahh, well....guess I'll just have to spend more cash on the 4PK |
08-20-2010, 11:42 AM | #6 |
| Have you looked into the Nomadio radios?? The React can use older Spektrum Rxs....and you can run a super (dual motor, front/rear steer with different mixing options) on the React using the Nomadio Transcievers... The React is MUCH cheaper than the 4PK as well.
08-20-2010, 11:47 AM | #7 |
Pebble Pounder Join Date: Jun 2008 Location: PISCATAWAY
surface radios only work with surface rx and air radios only work with air rx i tried when i had a dx3r and a dx6i i upgraded to a 4pk and love it but my dx3r was a great radio also
08-20-2010, 11:50 AM | #8 |
What's wrong with the dx6? Can run dual esc and give ya more control than a 4pk. |
08-20-2010, 12:20 PM | #9 |
| It's all about consistency, I've yet to see someone be as smooth with a stick radio as is possible with the 4PK. Not saying it isn't possible just saying I still haven't seen anyone good enough to do it. 4PK's FTW (at almost every major event this year) |
08-20-2010, 02:40 PM | #10 | ||
Not having a 3 pos. switch to use for dig means you have to use both 2 pos. toggles mixed, and there's been plenty of confusion on my part as to which way one switch is when you trip the other. If they aren't tripped the right way in conjunction, the end point adjustments get all mixed up and I've already stripped a couple dig servos. I figure having something with a third channel 3 pos. will make some things just easier.....and even though I don't "need" the expensive radios to get that 3rd channel, I am a firm believer in getting what you pay for and buying somethng for the long haul. | ||
08-20-2010, 03:03 PM | #11 | |
Quarry Creeper Join Date: Feb 2008 Location: Albany
http://www.spektrumrc.com/FAQ/tm.aspx?m=16 From there web site. Can I use the 3-channel SR3000, SR3100, or SR3500 surface receivers with my DX6? - The surface receivers use a different protocol and will not operate with the DX6. | |
08-20-2010, 08:48 PM | #12 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
There is no SR6000, I think you got it confused with the AR6000 which a lot of crawlers who use the DX6 etc are using. That rx is not compatible with the DX3R, however the older DSM1 rx's are. I have several older rx's from the original DX3 that I am using with my DX3R. With Spektrum, SR and AR rx/radio's are not compatible with each other. Hope that helps. Never touched a 4PK but I do love my DX3R.
08-20-2010, 08:53 PM | #13 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
I've owned a DX3R and currently own a 4pk...so far I like the 4pk better
