08-20-2010, 07:38 PM | #1 |
Newbie Join Date: Aug 2010 Location: Austin Tx
| xl-5 braking question
I just bought a Traxxas xl- 5, the braking is crap. Can something be done to help this ? Is there a way, to boost the amps increasing braking power, or set up some kind of switch? or, is hitting reverse, for braking? I bought a XL-5 yesterday, thinking that it had a better brake, for crawling or stopping.
08-20-2010, 07:52 PM | #2 |
Newbie Join Date: Apr 2008 Location: Auckland, New Zealand
It should have a perfectly capable brake. How's the reverse power? Have you calibrated the ESC against your transmitter? If you have, have you since tweaked the transmitter trim or EPA, or expo, or ATV, or ...?
08-20-2010, 08:16 PM | #3 |
Are you talking about drag brake? The brake should work just pushing the trigger forward.
08-20-2010, 08:30 PM | #4 |
There are many people that use the XL5 as their scaler ESC. It handles all brushed motors up to 15T, waterproofed already, and can take 3S no problem. If you want you can program the ESC in reverse order so that you have zero delay to go into reverse. The downside is after reversing you have to double tap to go forward but it does help with your braking issue. The only thing is you have no drag brake and no lipo cut off. |
08-21-2010, 10:49 AM | #5 |
Newbie Join Date: Jul 2009 Location: Petaluma
Going into reverse doesn't always solve the problem, like when you are on a steep decent, and end up doing a front flip because the car is so nose heavy. I'm also interested to hear if there is a way to improve the braking, I also run a xl-5, and I have always just dealt with the crappy braking, but it would be nice if it could be improved.
08-21-2010, 07:22 PM | #6 |
At the middle neutral point. When the throttle trim, is turned, just barely, it'll start to squeal either way.as same with the trigger. I tried the reverse tweaking, tuned it back to factory settings. As far as performance goes, braking aside, I can't complain to much. Water proof, and the profile settings. The training mode go tried, because it's got a 100% braking. along with 50/50 power cut, thinking that that might help the braking weakness. As I've read, in here some where, Good finger control can work just almost as well as a drag brake. The only thing the drag helps with, is steep inclines. rock gardens, creek beds, it works nicely. At some point, a thrasher truck. Put the receiver in a balloon, Drive it through creeks and not worry. i'd like to know, the mini erevo & 1/16 scale, is that the smallest rc car it'll fit in?? with a 540 size can. I know that's slightly off topic,it came to me as option. I wonder, if that combo, will work in a mini t w/a 3s lipo.....lol mods so far added To: Axial scorpion Integy roll cage. red springs on front (super soft). white on rear (soft /Losi) clearance links ( off brand) stock shock, axles, tires, wheels, w/ wieghts in wheels frnt/rear upgrade kit pivots and screws stock tranny/ no mods Futaba MS T2PH transmitter/ receiver XL-5 esc Axial 55t motor Hiech 645 servo 13/14/16/21 pinions 87 tooth spur in process of changing out, ring screws with studs/nut coming in future replacement parts front alum spindles, and change to Flat Irons, different wheels metal drive shafts stroner axle housings over drive the front diff maybe a dig screw pinion haven't decided frnt or rear or both maybe a dig mby tube chasis(moon buggy style) a upgraded esc (not sure which one) That'll depends if get the screw diffs. then no drag brake needed or use along w/ brake possibly staying brushed but adding lipo not in order of list.. |
08-22-2010, 10:49 AM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
The xl-5 has no drag brake, instant reverse, lipo cutoff or adjustability. Really a terrible crawler esc! If all ya care about is waterproof get a ballon, liquid tape for the stock axial esc or better yet a HH torquemaster. Last edited by oldhippie; 08-22-2010 at 10:52 AM. |
08-24-2010, 07:19 PM | #8 |
I just so happens. that it's water proof. it's just a temp esc. XL-5 going in a boat I have. i'm doing some looking around, to see who has a good esc, on this forum. I'm not much of a splasher. A non water proof esc is fine. The balloon trick, I've herd of. That was done at the factory.My problem is, I'm a really impatient with my hobby stuff. The Mamba. the rooster, or the HH torque master. Money is a limiting factor. So I look for inexpensive electrics. Be fore, One is bought, I look on this forum first. always. If some one, has a good used esc I'm open to that path also. I know with electric stuff, new or used electrics go out at any time. Thanks for the suggestions.
08-24-2010, 07:59 PM | #9 |
Rock Crawler Join Date: May 2009 Location: 354
| been using the XL-5 on all my scale crawlers for years now, and I think it works great, just got to learn it, but if your talking a comp crawler like his set-up then I would agree, it's not the best esc to use. |
