Thread: Heat sink fell out
Old 08-22-2010, 04:42 PM   #1
Default Heat sink fell out
I was installing my new castle mamba micro pro, I had mounted the esc turned,the chassis on its side and the heat sink fell out.
It appears that they are held in by some adhesive, I assume that it has,some kind of thermal property. I emailed castle and will prolly give them a call, but I was wondering if there is,something I can do instead of sending ir back.
WarTrader is offline   Reply With Quote
Old 08-22-2010, 04:59 PM   #2
yup thermal epoxy
2500hdon37s is offline   Reply With Quote
Old 08-22-2010, 08:08 PM   #3
Originally Posted by 2500hdon37s View Post
yup thermal epoxy
Any idea a good brand to use
Old 08-22-2010, 08:24 PM   #4
not a clue man, all i know is that is thermal epoxy (only know from knowing John Rob) but you can search Mcmastercarr.com
edit: found ya some-
http://www.mcmaster.com/#thermal-epoxies/=8isr7z
Old 08-23-2010, 08:21 AM   #5
I recently had this happen also, here's what I used:
http://www.newegg.com/Product/Produc...82E16835100013
John82601 is offline   Reply With Quote
Old 08-23-2010, 08:29 AM   #6
Same stuff that is used on the heat sinks mounted to CPUs....can be found at any computer supply store.
JeremyH is offline   Reply With Quote
