Thread: loosing throttle
Old 08-22-2010, 07:02 PM   #1
Default loosing throttle
I have a mamba max pro, external BEC (factory setting volts, stock axial servo (RTC kit), and a DX3 with that said my question is. ill be crawling for 10 mins and then all of a sudden ill lose forward and reverse but still have steering ill pick it up and everything works. sit it down again and with 30 secs or min same thing and im not always in a bind or hard spot when it cuts out. should i turn the BEC up i just wasnt sure if the stock servo could handle it i have a 7954sh on the way
keithgemmill is offline   Reply With Quote
Old 08-22-2010, 07:07 PM   #2
also the green and red lights are coming on like they are supposed to its just not moving
Old 08-22-2010, 07:19 PM   #3
Im not totally familiar with your esc in particular but I would say recalibrate and see if that helps. Whats your battery voltage when this is happening?
SMR 510RR is offline   Reply With Quote
Old 08-22-2010, 07:37 PM   #4
my battery is no where near dead 1300 mAh 3s and i charged to it so see and it was at 12.6 staring out on the charge and my cutoff is 9
Old 08-22-2010, 08:52 PM   #5
Angry
i figured it out the red wire was broke off right at the speed controller board. my brand new mamba im not very happy this is my first castle product and my last cause this isnt the first problem i have had. i soderd it back and everything is good
