08-28-2010, 06:24 PM | #1 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
| EVX Dual Motor combo... lack of rear power
Ok runnin EVX Speed Controle, dual Integy 45's Got everything hooked up as normal on my Super but the rear motor seems to be getting less power than the front. The front is running 14g wire and the rear is a little less. maybe an 18g wire. standard bullet connectors. Would the smaller gage wire be causeing it more resistance than the front and there for not moving at the same rate? In some cases when messing around it works out for me and acts like a Dig. |
08-28-2010, 08:18 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
you should run the small wire in front and the bigger wire to the rear..moa,s will have stall on the motor with the most load (rear), this is a fact about moa..so by running the thinner wire in the front and bigger in the rear it will allow a bit more juice to the rear and a bit of resistance to the front hopefully comeing out fairly equal..also you can run 1 tooth smaller pinion in the rear and that will help some
