08-30-2010, 08:09 PM | #1 |
Newbie Join Date: May 2010 Location: Mesa
| 3 cell 9.9v LiFe issue
Hey guys, I have a Turnigy 9.9v LiFe that is reading 0.0v at the connector. I pulled it apart and I don't see any issues with soldering. I checked and each cell is at 3.33 or 3.34. I can' t find where I am losing connectivity. Any help on where or what to look for?
08-30-2010, 08:16 PM | #2 |
Sounds like a bad joint on the connector. Fake deans on there, or bullet plugs?
08-30-2010, 08:53 PM | #3 |
Connector is good. I unwrapped the pack, and have checked voltage at each cell, and at the solders where it comes out. I am getting voltage at the solder joints for each one. I am just unsure of exactly how this cuircut is built. I am not getting the same readings at the ballance plug as I am at the solder joint it's self. and help?
08-30-2010, 08:55 PM | #4 |
So if you test where the main discharge wires are soldered to the pack, do you get 9.9v there? Could be a broken trace on the PCB. Did you short the pack by chance? That will "break" them.
08-30-2010, 09:18 PM | #5 |
Checked at the main discharge leads and nothing. I did short it. Is that not fixable? I have shorted across many auto batteries in my years as a auto tech, and not broke them. If it's shot, oh well, but i would sure like to make it work.
08-31-2010, 05:29 AM | #6 |
Inspect the PCB that connects the cells carefully, maybe post up a pic. I bet you broke a trace on the pcb.
08-31-2010, 03:08 PM | #7 |
Thanks, I will look it over real well and get a pic up when the wife gets home with our camera. Any tips on what exactly I am looking for on the PCB?
08-31-2010, 04:46 PM | #8 |
Looks for a little burned spot.
