08-31-2010, 07:30 PM | #1 |
Newbie Join Date: Aug 2010 Location: Eastern Washington
| Brushless outrunner quetions
Ok so can I run 2 brushless outrunners with only 1 esc (cc mmp) Im building a losi moa and already have the outrunners. also i will be using a cc bec at 6v and a 3s lipo 1300 mha. I guess if ya need more info let me know. Thanks for your time |
08-31-2010, 08:06 PM | #2 |
No, the way the ESC reads the info from the motor would mean each motor needs it's own ESC to properly understand where the motor is in its rotation to make it work.
08-31-2010, 09:14 PM | #3 |
Ok so could i run the cc side winder micros. Or could i flip the pos and neg that way one motor push and one pulls. Last edited by TOPWOP04; 08-31-2010 at 09:38 PM. |
08-31-2010, 09:43 PM | #4 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
a micro sidewinder will work fine with an outrunner 1200kv or less on 3s. |
08-31-2010, 09:45 PM | #5 |
ya but could i run 2 of them
08-31-2010, 09:59 PM | #6 |
| yes we run 2 esc's in rigs all the time. Use one battery and wire the + and - of each esc to the same battery plug. Each esc will run one motor. You can run them separately for independent control with a 4pk or stick radio, or use a y adapter on the receiver leads and run them both on the throttle of any 2 or 3ch radio. You will want a reversing y adapter for the receiver leads in an MOA to get the motors running in the same direction. |
08-31-2010, 10:07 PM | #7 |
ok cool thanks
