09-02-2010, 06:41 AM | #1 |
I joined the Band! Join Date: Jul 2010 Location: Chile
| Problem with esc and receiver, Help please
I got the roster crawler and novak 45t motor, my transmitter is airtronics mx sport and receiver is airtronics 2.4ghz 3 channels. well the problem is i connect everything, and im just getting reverse, the light when is neutral stays in red , when reverse it flashes green and when i go forward with the transmitter it changes to green but no movement. i have tried changing the configurations in the transmitter but no results, i have reprogrammed the esc many times aswell. please, can you give some directions, this is my first scaler and im getting a bit disappointed. thanks very much in advance. |
09-02-2010, 09:08 AM | #2 |
Rock Stacker Join Date: Sep 2010 Location: Netherlands
I see that there are 10 model memories in that radio. Are you using a new - everything set to zero / centered - memory spot? Do you have other RC's that you can bench test on? Different motor in esc, different esc with motor, etc. The best advice I can give is to just walk away and so something else for a while, come back and start at the very beginning. |
09-03-2010, 05:29 AM | #3 |
Well, i went away for the day and i tried everything again, i dont have any other Rc on which tried the transmitter and receiver. so i did some test with a multimeter trying to figure out what is wrong. i found the followings with the motor connected in reverse full throttle i got 7.8 volts. (full spin on wheels) with motor connected forward i got 23.1 mVolt (not spin on wheels) if i disconnect the motor from esc and i check voltage in the wires this is the result with the motor disconnected in reverse i got sames 7.8 volts as with the motor connected. with the motor disconnected forward i got 5.6 Volts, it seems that when the esc is connected to the motor is does not give the power for forward. i did connect the motor direct to a source of power and it spins normally i dont know what else to do. any suggestions about what could be the problem? |
