09-07-2010, 08:25 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
| Futaba 3PK Radio w/ Fasst System
Ok i'm looking for opinions good or bad, im running 2 esc's in my bully and dont want change that. 1 esc with punk dig in another MOA. My bully has a moded dx6 and i cant get use to it. And the other one has a moded dx3. I like it. So the Futaba 3PK Radio w/ Fasst System seems to have everthing i need. Lipo,mixing and what not . Tell me what you like or dont like about the system. Thanks
09-07-2010, 10:55 PM | #2 |
Rock Stacker Join Date: Sep 2010 Location: Netherlands
I don't think you will be able to run independent front / rear motors on the 3PKS because the 3rd channel is an on the fly on / off - at least that is how my rear wheel steer (non-crawler trucks) are set up. It's a fantastic radio for anything that needs 3 channels total. |
09-07-2010, 11:25 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Look at the 4pk thread. It explains how to run dual esc on 3 channels with the 4pk. The 3pk works exactly the same! All the futaba radios have more features than spekturn imho. The only problem with the futaba radios is the receivers are bigger (there is a new little one) and more expensive than spekturn.
09-07-2010, 11:38 PM | #4 |
I'll have to check out the 4PK thread then. Thanks |
09-08-2010, 07:23 AM | #5 |
Instead of making more threads, I'll keep my questions in here... I seen a video where the guy had 4ws (mix, crab crawl and independent rear steer) Skip to about 1:25 --> http://www.youtube.com/watch?v=8uppq...eature=related I would like to do all of that at the same time and be able to use dual esc. Is it possible? |
09-08-2010, 07:31 AM | #6 |
I just found my answer by looking that this diagram from the 4pk thread... Wiring Diagram For The Ultimate 4PK setup for 2.2 MOA's <---This needs to be updated for the newest RECOMMEDED setup. The Front ESC is now in Channel 2 and the rear ESC is in CH3. The 4th Channel can be used for the BEC or another accessory. With only 3 channels, I can either have dual servos or dual esc's but not both. |
09-08-2010, 08:11 AM | #7 |
09-08-2010, 09:34 AM | #8 |
Looks like a 6+ channel radio is in my not so near future... Knowing the Law of Murphy, I could buy a 14 Channel radio and need a 15 Channel one the day after I am able to return / exchange it |
09-08-2010, 03:23 PM | #9 |
| Are you saying you like a stick tx better or that the mixing is better than the 3pk? Im not going to run 4ws. I dont see alot of guys useing the 3pk just wondering why? Cost or design?
09-08-2010, 03:40 PM | #10 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
I'm running the 3PK because I already had it. I was running touring cars for a few months and wanted a very capable radio, but didn't need to go overboard on a 4pk. The 3PKs can be found MUCH cheaper than the 4PKs if you don't mind buying used. The 3PK can run a spektrum module too so you can get the little tiny receivers that they spektrum runs. The 3PK is a little big and bulky but what are we, a bunch of big pu$$ies that cant hold a radio for 5 minutes at a time. I like it, its a good radio and has all the features that I could wish for to run my berg. I've got mine set up on Dual FXR's and it works exactly the same as the 4pk. Only downside is that if I decide to get a XR10, and actually use the cutting brake, I'll need to upgrade to the 4PK |
09-08-2010, 04:39 PM | #11 |
Thanks J thats the kinda info i was looking for. Makes me wonder why alot of the guys lov a 3r so much. I like runing 2 esc's because of the control and more function. I'm not conserned about the size just wanting a qaulity Tx. I cant get the hang of the DX6.
09-08-2010, 04:46 PM | #12 |
No prob man! I get so tired of people talking about how they don't like the Futaba's because of their size and weight and stuff. I've seen more spektrums lose bind than any other radio out there. The Futabas are heavier, but who cares. The Spektrum is light and whatever but seriously guys. Who can't hold a radio for 5 minutes. (whew, glad that run is over, now I can put down this heavy ass radio!) LOL!! The Futaba 3PK will blow the DX3R out of the water in any "REAL" comparison. |
09-08-2010, 08:06 PM | #13 | |
09-08-2010, 08:57 PM | #14 |
Pebble Pounder Join Date: Oct 2008 Location: Grand Junction, CO.
My favorite feature on the 3pk is the push button on the grip. It works as a momentary switch for the front dig. What I mean is you push it with your middle finger and your in front dig as long as you hold it down. When you let the button out you're back in 4wd. Being able to pop in and out of dig practically instantaneously, without changing my hand positions, has helped me a lot. I tried a DX6i but using a toggle switch to get in and out of dig was hard for me. Also using the steering wheel for the rear dig isn't as hard as it sounds once you try it. |
09-08-2010, 08:59 PM | #15 |
What do you mean setting the dig with the wheel? I also thought reaching for the the toggle on the dx6 was weird.Thanks guys for the help ill be buying one by the weekend Last edited by hardhead; 09-08-2010 at 09:04 PM. |
09-08-2010, 09:06 PM | #16 |
Quarry Creeper Join Date: Oct 2009 Location: St.Louis
I have both radios. Both have there pro's and cons. The futaba 3PKS is an awesome radio. I'm running 2 FXR's with mine. The only thing I don't like about the 3PKS running dual FXR's is the buttons. I can not get used to hitting separate buttons to engage the front and rear dig then have to hit the same button to disengage. The one thing I do like better about the DX3R is the button layout one the grip. If Novak ever comes out with their M2 ESC I will probably use the DX3R and sell the 3PKS. I'm not holding my breath though! Wish there was a way to map a 3 POS switch on the 3PKS with the mixing. I would be happy then! Also the 3PKS does not require the use of the steering wheel being turned to engage anything. The 3PK does! Last edited by prophetz; 09-08-2010 at 09:08 PM. |
09-08-2010, 09:20 PM | #17 | |
09-09-2010, 03:11 AM | #18 | |
Wouldn't you be able to run a boat on any 2 or 3 channel radio? Or is it because of all the extra features in the 3PK(S) that makes it much better? Sort of like 4 channels is better than 3 channels on a crawler. | |
09-09-2010, 04:07 AM | #19 |
So there's a difference in the 3pk and 3pks? I assume the sport is a better tx?
09-09-2010, 04:31 AM | #20 | |
From Futaba: Quote:
