09-08-2010, 05:57 PM | #1 |
| Need some antenna wire
I have a ar6000 and well one of the antenna wires cut its self apart on the case and it worked fine for a while but here at the last comp every time i went to go pick it up it would lose bind then since no failsafe is on one of the channels my rear esc flipped out on me, so i need a new wire before i get a gate or something. I called the lhs and spent about 20 mins search on here for all sorts of key words but no results really, where can i find the antenna wire for it. Its dsm and its one single strand, it doesn't have the outer brain membrane on it, just the inner strand. Also i know this is an crawler site but does anyone know the length of the wire on a ar6000 (for a dx6).
11-09-2010, 06:50 PM | #2 |
Bump
11-09-2010, 07:00 PM | #3 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I dont have the exact measurements, but it is the same size as the other wire on the receiver. you can purchase the wire at most hobby stores, but it seems your store can not figure it out. I believe DSM you are allowed as short as 3.5 inches before you loose distance. you can purchase this and solder and cut and it will work fine. http://www.horizonhobby.com/Products...ProdID=SPM9005 |
11-09-2010, 07:10 PM | #4 |
isn't this for dsm2, i have the stock wire but it would be about 1/8-1/4 in shorter if i resolder it so i wan't sure
11-09-2010, 07:15 PM | #5 |
yeah, but the wire will work. done it before. but how long is your wire? and how long does the instructions say you can have it? If you can reuse it, then re solder it if its not too short. |
