09-09-2010, 08:31 PM | #1 |
| Motor Whining
Ok now i think i figured it out but i want to know why. So i went out crawling to day and my rear motor seemed like it had hardley any power, and when full throttle it was making a whining sound, So i dealt with it for awhile, then it totally gave out, so i pulled each brush off f the comm then let it fall back down ( i pulled it up with the spring still on it), and it stopped whining. So what was causing this whining, its probably time to clean my motors but i ran out of cleaner and haven't had a chance to run down to the lhs.
09-09-2010, 08:35 PM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
i'd say there is dirt or something not allowing tension to be released on the brush or causing too much tension on the brush. could be wrong but if you pulled them out and snapped back in and the noise stopped then I would say that's what caused the issue. in a pinch i have used rubbing alcohol. edit: I would listen to eddie he knows what he is talking about. Last edited by ctracy; 09-09-2010 at 09:26 PM. |
09-09-2010, 09:24 PM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
How long are the brushes still? Has the comm been cut? Unfortunately, just spraying out the motor doesn't do much once the brushes get short and the comm starts getting grooved...... More than likely, a cut and new brushes will cure your problems. Later EddieO |
09-10-2010, 07:35 AM | #4 |
| They are 35t r/t warriors, i just bought them not too long ago so the brushes and comms should still be good, although they do run pretty hot since their on an losi moa, but i would hink they'd still be good. About how many hours can i run motors before they need to be cut. I'll pull the brushes out tonight and see the condition of the comm and look at the length of brushes.
09-10-2010, 08:24 AM | #5 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Br00d built!. Most motors will fall off in performance due to brush wear, springs losing tension, comms need truing or just plain dirty. It will be noticeable in loss of go, drag brake and effeciency. New brushes and springs, a comm truing and a good cleaning(be sure to clean inside the brush hoods really good. I use Lysol tub and tile cleaner,works wonders! That is where most of the current flows to the brush. Not the shunt wire!) If available a good magnet zapping will be great as well. After rebuilding break the brushes in right and let her eat!!! Last edited by TEDROCKZ; 09-10-2010 at 08:32 AM. |
09-10-2010, 08:37 AM | #6 |
Well, really, you guys should be rebuilding your motors a lot more often than you do... In racing, we would rebuild after every run at big races and after each race day at local stuff, though some did the every run thing at the week night racing too. A local guy, who is just a hobbyist, doesn't compete has been bring his motors to rebuild. He has a set of mine, a set of banazi and a set of fantoms, all used on the same bully based crawler he bought. I've been having to rebuild his stuff every 10 packs or so..... I've been rebuilding my Losi crawler motor a lot more often than other crawlers. The truck is cool, but its a lot easier to be hard on the motor with it because of the axles.... My berg is almost done and I will be rebuilding my motors before each comp... At worst, you can send the motors in......I'll rebuild them just for the cost of the brushes (2.50) and the shipping back.... Later EddieO |
09-10-2010, 08:52 AM | #7 | |
Bout what i average. But I just like doing it. Professional tinkerer | |
09-10-2010, 08:56 AM | #8 |
my front motor is doing way better though, which is the motor i beat on the most, its always hot, the rear motor hardly ever warm. I think my lhs lathes motor for cheap and replaces the brushes. Do think he has a magent zapper though. Also wouldn't lathing a motor too much cause it to lose power since your taking some of the comm away.
09-10-2010, 09:06 AM | #9 | |
All motors wear out, you can control the rate of that though. | |
09-10-2010, 09:10 AM | #10 |
Ok, well i'm looking into buying a lathe haven't quite wanted to yet because i want to see how well the new brushless motors jrh is making are going to turn out, a brushless moa would be awesome, then i won't need a lathe. I'll proably have the lhs cut my comms and replace the brushes, should by buy some special ones for him to use or are all the brushes the same, (not sure which ones he has)
09-10-2010, 09:25 AM | #11 |
In theory, as the comm gets smaller, the motor will gain RPM, but lose a tad amount of torque (we are talking very small amounts), but the loss of torque is outgained by the RPM gain, so the motor actually gains power....at big races, we would often cut the stock and 19t arms down to fairly small sizes to gain extra power.... Tedrockz is right, if you rebuild a little more often, its not uncommon for much smaller cuts to be made on the comm. While, I am not sure which warrior you have, its more than likely a 9mm or 10mm comm version, which have plenty on copper, so you can do cuts for a while......when the arm is done, you buy a new one and install.....no different than tires, bodies, etc... Rear motors get subjected to lots of weird stuff.....from weird throttle to digs, its not suprising we see rear motor problems first. I rebuild about 2-3 pairs of motors a week, most of which are not even motors from me(Banazi, Trinity, Fantom, JPH, HH, Integy).....and on all them (including mine) its been pretty common to see the rear motor looking more nasty than the front.... Later EddieO |
09-10-2010, 10:06 AM | #12 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
can the armature be chucked up in a normal lathe and have the comm cut that way rather than a dedicated comm lathe? All you're doing is take material off of it correct? And the time to stop taking the material off is when the comm is completely even? How much would one expect to turn down (thousandths wise)?
09-10-2010, 11:36 AM | #13 |
Sure can.....that's how Big Jim cut all his arms, in an older emco lathe. Reedy used a really cool one that was automated with air power....was very trick. I originally did it like Big Jim too, but comm lathes were simply faster and gave just as good of a cut.... Later EddieO |
09-10-2010, 12:22 PM | #14 |
I'm on am maching class now, i'm not going to, but what would happen if i mounted up a armature and lathed the comm on a full size lathe. I have the warrior r/t if it is the biggest comm either a 10 or 11mm i can't remember
09-10-2010, 12:46 PM | #15 |
As long as you mount it up correct, so you don't knock is out of balance, you will be fine.... Just make sure you have a similar style cutting tool like what we use (reedy and big jim used the exact same tools our little lathes do).... In the end, you are just cutting copper.....which is basically considered a butter metal.... Warrior R/T should be a 10mm comm Later EddieO |
09-10-2010, 03:38 PM | #16 | |
Clean is power. | |
09-10-2010, 04:38 PM | #17 |
so your saying.00025 or an inch Thats small. Are motor lathes really that accurate. The big lathes i've been suing are only accurate to .001, well the dials are, accurate compared to the calipers its more like accurate to .005-.010. Really bugs me when thats the same as our tolerances we have to be in,
09-10-2010, 05:12 PM | #18 |
Iiiiiiiiiiiiiii don't know how exactly small... my point was I'm taking off the smallest amount possible, but completely cleaning off the commutator surface with just one single pass. I do motors that guys beat on and completely neglected all maintenance and it might take 10 or even 15 passes at a third of a thousandth each pass. Let's say it takes me 15 passes to get a completely clean comm, cutting off 1/3 a thousandth every time. That's 5 thousandths total removed. Compared to mine taking a single pass, say a total of 1/3 of a thousandth removed. I can have a fresh cut comm 15 times (more power) compared to not taking care of it, and running it into the ground, losing performance every run, then needing a large amount to be removed to work its best again. I get fifteen clean motor runs, they get one. Clean is power. |
09-10-2010, 05:18 PM | #19 |
| I'm gonna do a pair for Austin that has been on his rig for an entire season, just changed them out for newer ones. You all know how delicate he is on stuff...Should be interesting!!!
09-10-2010, 05:42 PM | #20 |
Yeah, first thing I would do is measure the comm diameter and see if there's anything left to take off. |
