09-11-2010, 09:18 AM | #1 |
Quarry Creeper Join Date: May 2009 Location: The Tarheel State
| 3Racing Winch Problem
So, I got it with my Honcho kit but got sidetracked with life and am just now getting it put in. When I hook it up and press either the button on the control board or from my remote...it winds out and immediately winds back in. I cannot get it to stay out. Anyone else had a similar issue or have any thoughts? Do I need to contact 3Racing or RPP? |
09-11-2010, 09:39 AM | #2 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
What Tx are you using? Is the 3rd channel 2 or 3 positions? Is the trim on the 3rd channel centered? If its only a two position switch it will constantly wind. |
09-11-2010, 10:34 AM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: 801 El Capital
Ya try unplugging it from the reciever and then operate it from the button. It will probably work than,meaning it is how your remote is set up. If you are using a Traxxas 3 channel or at least from the thumb rocker it is only set as a 2 pos switch. Jason |
09-11-2010, 10:38 AM | #4 |
Pebble Pounder Join Date: Apr 2009 Location: Dallas
09-12-2010, 04:45 AM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: Canberra, Australia
I'm about to buy one of these winches too. I have a DX3S which, I think, only has a on/off 2 way switch for the 3rd channel. Does that mean you just have to manually flick the switch again when you want the winding to stop? Hit the switch the 3rd time - will it wind back in, or continue winding out to the maximum length??
09-12-2010, 09:16 AM | #6 | |
Newbie Join Date: Jul 2010 Location: San Diego
09-12-2010, 09:35 AM | #7 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
the motor isn't smart, it wont stop once your line is completly out, what it sounds like is happening is its unwinding, then rewinding on the drum in the oposite direction, once your line is out, PRESS the button again to stop, then press it again to wind back up. all in the instructions man. RTFM I have yet to try mine on my 3rd channel, but works just as instructed off of the button. |
09-12-2010, 09:41 AM | #8 | |
However you can search for the servo control option. It takes up room but works quite well. You use a micro servo to push the button on the controller the winch comes with.It works like on/off lets the line out on/off stops the winch on/off spools the line back in on/off stops the winch savy Jason | |
09-12-2010, 09:43 AM | #9 | |
09-12-2010, 06:24 PM | #10 |
I just hooked my winch up for a bench test and totaly understand your issue, this will not work with a 2 pos. 3rd chan. :( maybe there is a work around but from bench testing atleast 3 pos. seems to be needed.
09-12-2010, 09:43 PM | #11 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
hey, i have a different winch problem question. I turned my scaler on today and my winch worked fine last outing and now it only responds one way. I can reel it in but it will not reel out. I even tried reversing the aux on my radio and it still only turns one way. anyone have any ideas for why this is happening and can it be fixed? |
09-14-2010, 06:48 PM | #12 | |
Now back to the serious responses. Thanks to everyone who weighed in, I am using the Spektrum DX3S, so based on your answers it appears that is the problem. | |
09-14-2010, 06:50 PM | #13 | |
09-14-2010, 06:55 PM | #14 | |
Then my apology right back at you. Multi-tasking and to be honest after I got to your first thread I didn't read your later ones. | |
09-14-2010, 06:58 PM | #15 | |
I re-read your question and it says it wont stay out when you used the button on the 3 racing board either? try unplugging the signal wire from the 3rd chan. spot on the reciever and trying it again, with no way of outside interfierance. | |
09-14-2010, 07:13 PM | #16 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
what 3 channel controller would you guys recommend using, so that the winch does work correctly on the 3rd channel ?
09-14-2010, 07:59 PM | #17 | |
Rock Crawler Join Date: Dec 2009 Location: Ontario Canada
you can use a Traxxas TQ remote... and somewhere in here ther's a how to on modding it for a 3 position switch here's page 15...as it uses the already existing red switch on a TQ3 to turn it in to a 3 position... My Modded TQ3 Update - Added EPA pots | |
09-14-2010, 08:17 PM | #18 |
thanks,i mite give that a try myself
09-14-2010, 09:27 PM | #19 |
Pebble Pounder Join Date: Jan 2009 Location: Yacolt, wa
I've got to say don't waste your time if you want to actually use the winch. Just do a servo winch. These little 3racing winches just have no power
09-15-2010, 07:29 AM | #20 |
Newbie Join Date: Jun 2010 Location: Upstate N.Y.
the RC4WD Bulldog winch has a better pull rate and offers a wireless remote control. It also has a plastic coated steel cable and king Kong hook. I feel it's well worth the little extra $ over the 3 Racing winch.
