09-12-2010, 09:42 AM | #1 |
Rock Stacker Join Date: Aug 2010 Location: Houston
| Tekin FX-R solder posts
The wires that came with my ESC are too thick to fit inside the solder post notches. Will there be issues if I trim off some of the exposed wire to make it thinner so it will fit inside the notch? Or is it ok to just solder the wires on top of the posts but not inside the notches?
09-12-2010, 09:47 AM | #2 |
Solder on top, don't mind the notches.
09-12-2010, 11:58 AM | #3 |
Thanks for the quick reply! It should be super easy then.
09-12-2010, 12:25 PM | #4 |
Quarry Creeper Join Date: May 2009 Location: brentwood
you can just solder it to the post!
