09-12-2010, 01:17 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
| cutting off the on/off switch???
How does one safely cut the on/off switch on thier esc such as fxr and MM? Just snip ot off at the case or what? I am running with bec now and no longer need to use the on/off switch. It's getting in the way now. Thanks for any advise.
09-12-2010, 01:33 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
On my sidewinder I cut the switch off and then soldered the leads together and covered with shrink wrap. My Fxr doesnt have a on/off switch that I can remember. I thought it was just plug and play? Could be wrong been a while since I've seen mine its been in my honcho in the electronics box since I got my honcho.
09-12-2010, 01:36 PM | #3 |
09-12-2010, 03:52 PM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
I bridge the solder joints on the board and get rid of the wires on my esc's...I also shorten the rx wires at the board while I have it open. Doing it this way might void your warranty...I've never had to warranty an esc though.
09-12-2010, 05:02 PM | #5 | |
| Quote: I did use the search, but didn't come up with that one. Thanks!!! | |
09-12-2010, 07:29 PM | #6 |
Quarry Creeper Join Date: Jan 2010 Location: Albuquerque
| yup
This is the way to go. (unless you're new to soldering...you can wreck the board in a micro second if you don't know what you're doing) If you're new to soldering, just solder the wires together and shrink wrap em. |
