09-13-2010, 09:47 PM | #1 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
| 4-wheel steering (BEC wiring)
So, I am running a BR-XL which has a pretty good internal BEC, however, it is rated at a lower voltage than what I want to run to my rear steering. I am running dual HS-7954SH servos, and want to run them at 7 volts. Check this diagram. Question: is the 10A BEC acceptable for running two steering servos like this? Am I pushing it a bit? Casey |
09-13-2010, 09:49 PM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
im thinking why risk it for 20 bucks? are you soldering the wires from bec to servo or using a plug?
09-13-2010, 09:50 PM | #3 | |
It is not a question of risk. Worst case scenario is a bind "might" cause the setup to hang....I stress might. EDIT: keep in mind, a BR-XL has a 6A internal BEC, IIRC, and is considered by many to be more than adequate for most applications (single servo). Casey Last edited by KC_JoNeS; 09-13-2010 at 09:54 PM. | |
09-13-2010, 09:53 PM | #4 |
i asked about the soldering cuz i am hooking mine up tomorrow and didnt want to run to lhs for plugs. so i was gonna solder them. castle is local here in kc. not sure if they have 800 number. i gotta call them anyways to see how I send my bad bec back.
09-13-2010, 09:55 PM | #5 | |
Dont ask me how I know that. | |
09-13-2010, 09:58 PM | #6 |
lol thinking thats how first one went bad. wouldnt hook up to castle link. no volts at plug with battery power. first crawler and first bec so I am learning.
09-13-2010, 10:28 PM | #7 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
thats the same wiring im running, however i found it was very glitchy and i had to add a ground wire between the bec output and the receiver. that completely fixed the massive glitching i was having. i myself run plugs on everything. if i was to have a servo fail and someone had a spare i could swap it easy. if its soldered it means the day is over. i cant find the specifics, however i remember reading that one of the hv servos would pull around 4.2 amps at stall, so you should be ok with one bec. |
09-13-2010, 10:35 PM | #8 | |
Casey | |
