Thread: FXR- BEC-DUEL-MOTORS,,is the
Old 09-15-2010, 08:46 PM   #1
Default FXR- BEC-DUEL-MOTORS,,is the
BEC needed...........rig took a hard fall and now the BEC does not work,the shock from the fall must have did something to it because now no power comes out of it.
question is : with an FXR speed control,and the thermol shut down that happens with a single motor and 3s lipo, will a duel motor still make it thermol with out the BEC or is it still needed.
big dude is offline   Reply With Quote
Old 09-15-2010, 08:53 PM   #2
do not run a fxr without a bec in a crawler!
oldhippie is offline   Reply With Quote
Old 09-15-2010, 09:21 PM   #3
X2 a bec is cheap and you can adjust the output voltage.
Failedabortion is offline   Reply With Quote
Old 09-15-2010, 10:02 PM   #4
yeah I figured as much ,just making sure.
THANKS A BUNCH
