02-28-2006, 05:59 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: *
| another servo If I add another servo for a dig setup, am I going to need to add a Rx pack or the TR2???Im currently running the XRS...The only reason I ask cause the dig wouldnt be used as often as 4ws and such.... |
02-28-2006, 08:37 PM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
What kind of vehicle? Just wondering why you need a servo to do a dig A total of 3 servos? What kind of servos (digital/analog)? digitals will def. strain the BEC more than analog I have run 3 HS-645mg servos off of the TR2 and it performed perfectly, but I am not sure if that was harmful in the long run. The TR2's BEC gave out a couple months later (while using a 1/4 scale and 1 645 servo). Whether or not running the 3 servos was a factor I have no idea, just my observations. |
02-28-2006, 08:56 PM | #3 |
Just one 645 and one cheap s3003 futaba to run the dig...Too much strain on the XRS???
02-28-2006, 09:04 PM | #4 |
I would think that 2 servos is too much for the XRS 5volt/1amp BEC, but I have no personal experience with that esc. Another option, instead of forking out for a TR2, would be to buy a Novak Nitro Servo Regulator ($20). It supplies 3amps to the servos from your main pack. I am now using one of these and like it so far, since I killed my TR2's BEC. |
02-28-2006, 09:20 PM | #5 |
done deal..Thanks sven can I get them at tower??? Found them thanks Sven... Last edited by k9popo; 02-28-2006 at 09:24 PM. |
02-28-2006, 09:31 PM | #6 |
If you want I will post a picture of how my Novak regulator is set up. I made a Y-connector from Deans plugs so it is not permanent and I can put it in different vehicles.
02-28-2006, 09:49 PM | #7 |
The regulator does not come with any connectors, but the leads do come nicely pre-tinned ready to be soldered to something. You will use the on/off switch that the regulator has, instead of the one on the ESC. Plugs into the BATT port on the receiver A shot of the connector I made, it goes between the battery and the ESC. And the entire setup Last edited by SVEN; 02-28-2006 at 09:52 PM. |
03-01-2006, 11:10 AM | #8 |
Thanks Sven thats awesome...I really appreciate your help and those pics are sweet..... |
03-03-2006, 10:52 AM | #9 |
That mess of wires looks like one of my builds!
03-03-2006, 12:13 PM | #10 | |
Like this: Last edited by SVEN; 03-03-2006 at 12:16 PM. | |
04-13-2006, 11:26 AM | #11 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
hey sven, I have a question about the servo regulator.I dont need to switch my ESC on?So I can cut the switch off and seperate the two wires,correct?Well,my switch snaped off.=)..Thanks! |
04-13-2006, 11:43 AM | #12 |
WestCoastPJ: I have no idea about whether the switch can be cut off. But you are correct about not having to turn it on when using the regulator. Dezfan: haha, yeah well that was the first motor I ever got (P2K) and it was used....7 years ago. I just threw it on their until the lathes came in. It's been soldered and resoldered so many times, it is a complete mess. |
