09-18-2010, 04:15 AM | #1 |
Rock Crawler Join Date: May 2007 Location: Norwich
| Mixing puller motors
What would be the result of mixing a 55 turn motor with a 400 14 turn puller? Single fxr on 3 cells. Would a 45 work better? Would it work at all? Any help from those with the knowlegde would be greatly appreciated. -Curt |
09-18-2010, 12:28 PM | #2 |
Do you mean trying to make a 55t puller? Pullers aren't wired like standard motors. I've tried to figure it out, but there is some kind of voodoo going on there... |
09-18-2010, 12:40 PM | #3 |
The 14t will be fast, but stall easier. The 45t or 55t will be slow. You may be able to work something out. Is this MOA? Maybe a 35t on back and the puller on front.
09-18-2010, 02:49 PM | #4 | ||
Thanks for the replies. Curt | ||
09-18-2010, 04:04 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
I run the 14 turn pullers on my berg and they are way faster than the 35t that they replaced. I ran 12 tooth with the 35t and I run 11 tooth with the pullers and they are still that much faster, and the epa's are set at 90% with 3s lipo. Weight is right at 5 lbs. Hope this helps, TY
09-18-2010, 04:45 PM | #6 |
I guess my biggest question is which motor will draw the most current? I would assume the motor that wants the most current will stall first? If someone could confirm this it would be great.
09-18-2010, 07:01 PM | #7 |
The puller will pull more amps than the 540 motor.
09-18-2010, 07:09 PM | #8 |
Yeah, those pullers are amp hogs for sure. You probably just need to get first hand experience in the matter. I don't think it has been done. |
09-18-2010, 07:14 PM | #9 |
If I was gonn mix a puller with a 540.I'd put the puller in the rear and mate it with a 35t up front.
09-18-2010, 09:22 PM | #10 |
