09-19-2010, 01:34 PM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: Indonesia - Rock Heaven
| HELP: Airtronics MX-3 Vs 3Racing Winch
Hi, I'm having trouble pairing an Airtronics MX-3 with a 3Racing winch. I followed the instructions and everything is fine EXCEPT: I can't make it stop, the Aux lever seems has no neutral position. Up is for pull and down is for release that's all, no stop/neutral position to make the winch switched off...any suggestions? Thanks in advance. |
09-19-2010, 01:49 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
it needs a 3 position switch to operate correctly. you need forward, neutral and reverse to be able to run it right. the mx radios only have 2 position switches, you might be able to adjust epa's on the fly to get it to work though. or have 2 different model memories... one to run it out and to neutral, then another model with different epa settings, that will run it back in and has neutral. that make sense? that's how I ran my dig with my mx-3fg
09-19-2010, 01:51 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
I had the same? a while back ago and found a salution from a thread on here. I'll try to explain it the best I can. First you have to find the right end point on your controller and turn it down to 0% and put the other around 50%, that way you have neutral one way and movement the other way. Then access your aux servo reversing option on your controller and what your going to do is hit your 3rd channel switch and it well throw one way and then hit it again and it returns to neutral, then when you want it to go the oppesite way hit your servo reverse then hit your 3rd channel switch and it throws the oppesite way. Hope this helps, theres a thread on here some where that explains a little better then me lol.
09-19-2010, 01:55 PM | #4 | |
09-19-2010, 02:32 PM | #5 |
yeah in effect the solution jrock has is pretty much the same thing, but gets to it by a different route. the different model memory is probably better in that the epa's will be more accurate, just reversing the switch as he described doesn't guarantee you'll have the proper throw in each direction, but it will probably be pretty close. if you keep it on the battery tab on the little screen, if I remember right model selection is only a single click of the arrows, then you just program the next model in sequence to be the one with your flipped switch... and you can even have the two channels identical for every other epa, so you can pilot the rig off either one depending on if you want to be able to winch out or in.
09-19-2010, 02:57 PM | #6 | |
09-19-2010, 02:57 PM | #7 | |
09-19-2010, 04:21 PM | #8 |
No problem, glad to help |
09-19-2010, 06:21 PM | #9 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
09-20-2010, 12:44 AM | #10 | |
| Quote: | |
