10-07-2010, 12:06 AM | #1 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
| Batteries in parallel
Hey guys I have a very limited knowledge on batteries and electronics in general. I was wondering about wiring batteries in parallel: I have 2 1900 nimh 6 cell stick packs and was wondering if I wire them together will it go up to 3800? Right now I could get like 10min out of one of thoes batteries is there a estimate on the run time after wired together. Thanks for the help. Adam |
10-07-2010, 07:02 AM | #2 |
Yes, when you wire batteries in parallel, the voltage will stay the same and the capacities are added together. Now, the real question is why you are getting such crappy performance from your batteries? I run one of my scalers on a 2700mAh pack and get about 2 hours of runtime. It sounds like your packs are not getting fully charged. Which can either be a problem with the charger or the battery. |
10-07-2010, 07:24 AM | #3 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
My guess would be the pack probably isnt getting properly peaked.
10-07-2010, 07:26 AM | #4 |
That is what I was thinking as well....
10-07-2010, 07:32 AM | #5 |
more info on the truck and electronics would be helpful too... and how old are the cells?
10-07-2010, 08:17 AM | #6 |
These babttries are kinda old I think they are piranha's I just got them from my brother In law as he was cleaning out. His garage. My truck is running a side winder with a brushed motor eaither 45 or 55 can't remember. Just a crappy servo from my t-maxx. My charger is a vision peek 2 charger it says they get charged up all the way. I usually charger them on 2 amp |
10-07-2010, 08:37 AM | #7 |
| if they are old and piranhas thats probably your problem. They werent good cells to begin with.
10-07-2010, 08:39 AM | #8 |
Yah they are kinda beat up. Thanks a lot for ur help guys.
10-07-2010, 08:57 AM | #9 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
How long are the bats on the charger before they peek? At 2 amp charge rate 1900mah packs should take about an hour to charge. If they are peeking in like 15 minutes, they are false peeking (not fully charged) hence your short run times. With your setup and 1900s you should see at least an hour run time per pack. |
10-07-2010, 09:01 AM | #10 |
It takes about 25 to 30 minutes. The battery I am running in my truck now only lasts a half hour and it's a 3000
10-07-2010, 09:09 AM | #11 |
I have anouther question too. I just got a turnigy 420 lipo charger. And I was wondering does any one know if it balances the lipos also. It charges through the balance plug but I don't know if I balances them also
10-07-2010, 09:41 AM | #12 |
Yes, it will balance them. Don't ever charge nimh or nicad in parallel, as the "peaked" cells have a lower resistance and they will overcharge as compared to the other cells in parallel. You can discharge them in parallel. |
10-07-2010, 09:54 AM | #13 |
So if I wire these batteries in parallel how do u charge them
10-07-2010, 09:55 AM | #14 |
You take them apart and charge them as two packs.
10-07-2010, 09:58 AM | #15 |
Ok. So to wire them in parelell would u have a deans plug on both battery then make some sort of y harness to plug them both into ur esc
10-07-2010, 10:02 AM | #16 |
yep |
10-07-2010, 10:09 AM | #17 |
Cool thanks a lot
