10-07-2010, 11:33 AM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Wilmington
| break in for new motor
Which break in is best? How do you break in the motors for each method? Thanks
10-07-2010, 12:09 PM | #2 |
Newbie Join Date: May 2010 Location: Ft. Lewis
wow no one? search google, seen some do water break in |
10-07-2010, 12:13 PM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Do a search on the forum there are a lot of people who have written about this. The best way in my opinion is the water method.
10-07-2010, 12:14 PM | #4 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
| You know it can take longer then a 1/2 hour to get a reply. not everyone is on here 24/7 the water breakin is good, you can also run your truck with the motor in it very lightly the first run. Dont push the motor and dont floor it. just lightly run it Last edited by PontiacGT201; 10-07-2010 at 12:17 PM. |
10-07-2010, 12:23 PM | #5 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
The search button is your friend!! Here are a couple of good threads on motor building and maintenance that i found using the search button... (HH) Tech Questions and Customer support thread Cutting a motor commutator & motor tweaks Motor break in |
10-07-2010, 01:09 PM | #6 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
The water break in method is not needed.... Run the motor at 3 volts for 5 minutes. Check the brushes, see if they are wearing evenly across the entire face. If they are, you are good to go. If they are not.......run for another minute and check again. Repeat until they wearing evenly across the entire face.... The water break in method is VERY old and really only should be used on sealed can motors......all it really does is speed it up. Certain brushes don't like it at all and often the motor isn't cleaned properly afterwards, which leads to other problems. 30+ national titles and not once did I ever break in a motor with the water method....I can't recall anyone else doing it either, with the exception of sealed can motors.... Later EddieO |
