10-14-2010, 08:36 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
| Internal BEC Question
Ok I just got a Havok Brushless system (I won it at our LHS) it is a 17.5 turn and I am going to use it on my comp rig. The question that I have is, it is supposed to have an internal BEC, but is that just to protect the ESC itself? Also I am getting some chatter out of my servo that is more annoying than troublesome, I am wondering if I get an external BEC and run the servo through it if that will fix it. Any help would be great thanks. |
10-14-2010, 08:43 AM | #2 |
Almost all ESCs have a built in BEC. The problem with using them in conjunction with a high torque servo on a crawler is that when you get your motor in a bind, the motor will draw current away from the BEC....leaving your servo without enough juice. An external BEC simply bypasses the ESC....
10-14-2010, 08:47 AM | #3 |
Cool thanks for clarifying! Do you think that running an external BEC will stop the chattering that I am getting from the servo?
10-14-2010, 09:02 AM | #4 |
Umm....I doubt it. What do you mean by "chatter"??
10-14-2010, 09:14 AM | #5 |
It is like the electric sound you get when the forward or reverse trim on the motor is set a little to high and it is trying to engage but just hasn't yet, if that makes any sense. If I move the wheel or tap the throttle it will stop but then if I hit the wheel again it will start again.
10-14-2010, 09:15 AM | #6 |
Ahh....I see. That is just the digital servo trying to center itself. When you pick the truck up off the ground, it goes away, right? If not, you might have a bit of binding in your steering system... Is this a Hitec servo? For reference, Futaba servos are a bit quieter.... |
10-14-2010, 09:18 AM | #7 |
Yeah it goes away. So how do I amke it stop because when I am running it around the house it is kind of annoying LOL, the wife was getting pissed lasst night because she couldn't study with the beeping LMBO |
10-14-2010, 10:21 AM | #8 |
you cant really make it stop thats just how digital servos sound
10-14-2010, 10:27 AM | #9 |
Ah ok thanks for the info guys.
10-14-2010, 10:28 AM | #10 | |
Seriously, as mentioned, that is how digital servos work....no way around that. | |
10-14-2010, 12:05 PM | #11 |
That or I can "make" her go to the dining room while I crawl in the living room LMBO. Cool I will just deal with it. I got to tell you I love this dang servo man this thing is powerful.
10-14-2010, 12:15 PM | #12 |
