10-15-2010, 07:42 AM | #1 |
Newbie Join Date: Jul 2010 Location: Italy
| How to reverse brushless sensored motor
Hi guys i need to reverse a brushless sensored motor. The esc not have a reverse. How i can to do? |
10-15-2010, 08:06 AM | #2 |
You have to swap two sensor wires and two power wires. You have 36 possible permutations of wiring. Only 8 work properly- four for each direction. You will need an amp meter to watch your no load current, as there are also 8 combinations that appear to work but have a very high amp draw that will kill the ESC or motor. The other 20 combinations don't work at all. Good luck, it is time consuming. |
10-15-2010, 08:14 AM | #3 | |
I have see some pics but i don't understand if it's ok for Speed Passion Esc: Thank you so much! Livio | |
06-24-2011, 08:49 PM | #4 |
Pebble Pounder Join Date: Jul 2009 Location: Sydney
In my sensor cable, there are 6 wires in the plug. Are these wires a paired item? ie A +'ve and -'ve, B +'ve and -'ve, C +'ve and -'ve
06-24-2011, 08:59 PM | #5 |
The sensor wire has a positive and negative pin, with an extra wire for a motor heat sensor. The other three are the sensor signal. The roar handbook has the pinout. I can't find the pic I have of the spec. |
06-25-2011, 02:05 AM | #6 |
Thanks for that. If you find that picture, or even a link to a thread it would be really handy at the moment.
09-13-2011, 07:45 AM | #7 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
Just found this now. Did you ever found a way to reverse it?
