10-17-2010, 10:52 AM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Motor upgrade
I run my Berg on Novak 45T's off of dual Tekin FXR's. They are about 1 1/2 years old. I notice the holding power is not that great. I THINK they were better before but not sure. Looking to upgrade to a stronger and faster motor for quick launches up ledges, as this is where my setup lacks. Should I look for handwound 45T's or 35T's? My rig is around 7.5lb, so that might be a factor. I want good bursts of power, but able to be controlled. Thanks!! |
10-17-2010, 11:05 AM | #2 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
4 magnet canned brood 35t. super smooth on the bottom end and plenty of rpm when you need it.
10-17-2010, 11:06 AM | #3 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Most bergs run 35t, seems to be the popular choice.... If you have not rebuilt the motors in a 18 months, I am gonna guess that the brush is very short......when the brush gets short, your spring tension decreases......spring tension is a big factor in drag brake performance. Later EddieO |
10-17-2010, 11:06 AM | #4 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
I would recommend a hand wound motor for sure! My new rig ill be runnin 35t BROODS on mine, i love them on the super and my buddies berg
10-17-2010, 02:01 PM | #5 | |
What is the breakdown of your lineup of different 35t's? Are the 5 segment arms available yet? I see the R has a 7.5mm Comm and the R/T has a 10mm comm...What is the performance difference? Last edited by Pappy; 10-17-2010 at 02:56 PM. | |
10-17-2010, 03:31 PM | #6 |
No 5 segment arms yet......I dunno if they will ever work really, but maybe one day I will get to try them again... Difference in comm size basically alter powerband.....smaller comm=more rpm and power......big comm little less RPM and more torque.....its not a huge difference.... the 4 magnet cans provide more power and smoother start up, along with better low power resolution.....but less drag brake. 2 Magnet is more torque and drag brake, but more abrupt on the start up. The Creep R/T is by far the most popular.... Later EddieO |
