10-24-2010, 01:41 AM | #1 |
Newbie Join Date: Dec 2009 Location: Fgura Malta
| FXR sincronization
I have a bully with two Tekin FXR and I'm using a futaba T6ex radio. Can some one tell me how can I sincroniz the fxr to the radio please??
10-24-2010, 01:57 AM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Push the mode button for 3 seconds while the remote is in neutral then full thottle then reverse when the lights blink... http://www.teamtekin.com/fx.html You can download direstions here |
10-24-2010, 03:30 AM | #3 |
I have made that but I think that I have to sincroniz them both at the same time because some times it cut off the throttle
10-24-2010, 12:31 PM | #4 |
Like one ESC goes dead on you? Are you running an external BEC?
10-25-2010, 08:05 AM | #5 |
yes I'm running an external bec and they both go dead
10-25-2010, 09:01 AM | #6 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
make sure all trims are 0 and all mixes are OFF, remember your 2nd esc is on the elevator stick (RS) youll have to sync them individually i would expect
10-25-2010, 09:16 AM | #7 |
No they are on the same channel because I run a novak dig
10-25-2010, 09:54 AM | #8 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
Push and hold the Mode button for three seconds and wait for it to find neutral then press and hold the mode button on the second fxr and wait for it to find neutral. Then squeeze the trigger and let them find forward. Then push the trigger or (stick) in the reverse direction and let them find reverse. They will both chime when completed. You have just synchronized them. |
10-25-2010, 10:18 AM | #9 |
Thanks Pdog7 and all of you for the help will try u synchronize them together and will see the result |
