10-25-2010, 12:12 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Cedar Rapids
| powering mamba micros
I was doing some brain storming last night, yes it hurt, could a guy power two Mamba micros from a punkrc dig? Then just wire the esc's like normal. Then to power the dig wire the battery to it. Reason I ask is to some what save on space and be able to mount the esc's at either end of the rig, and to an extent run dual esc on 3ch. thanks for any input |
10-25-2010, 12:17 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Battery should be plugged into the esc and the motors wires from the esc soldered to the punk dig board. If you're going to run the punk you only need one esc. |
10-25-2010, 01:48 PM | #3 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
Just get a Novak Dig. It will do exactly what you want without the Punk dig. You use 2 speedos and plug them both into the dig and you can control them just like a punk. And the novak dig is about the same size as a CC BEC.
