10-27-2010, 09:53 AM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Acushnet Mass near cape cod
| cc bec question
Ok so im not new to this bec stuff, but I have been having a problem with it. First I was not using one and had no problems. But everyone says you need one. So my problem is when I installed the bec in my crawler the steering cuts the throttle and motor stalls bad ,im gonna try a different motor. I have it wired in the same as my other vehicles with bec's ,and yes I have the castle link and have tryed uping the volts with no luck.only differece is this crawler has a novak 2s lipo cutoff installed. Setup is Losi mrc Novak lipo cutoff Hitec 645mg Insane 370 motor Stock esc |
10-27-2010, 11:14 AM | #2 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
Did you remove the red wire going to the receiver?
10-27-2010, 11:16 AM | #3 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
^^^^That^^^^
10-27-2010, 12:23 PM | #4 |
yes the wire is unplugged. If I plug in that wire everything works fine
10-27-2010, 12:43 PM | #5 |
Sounds dumb but are you sure your battery is charged up? The reason I ask is because when i hit the lipo cut off on my MMP the motor will move a little but seem like its cutting in and out but will still have steering
