Thread: radio fried lipo / need cut off help
Old 10-28-2010, 04:58 PM   #1
Default radio fried lipo / need cut off help
ok i guess i left my radio on and fried my lipo thats $60 bucks in the crapper.
i have an m11 radio it has no lipo cut off.
it has voltage alarm at 9.1 volts
looking to find an in line cut off that will protect my battery
talked to novak about there lipo cut off but it only works on the siginal wire
not the power wire.
is there a way to do this with out breaking the bank
i dont realy understand all this tech stuff so plain english please
thanks mike
dmgriff266 is offline   Reply With Quote
Old 10-28-2010, 05:10 PM   #2
Are you referring to the Lipo in the radio ? If so i cant help you,
If your talking about the lipo cut off for your car then its not in the radio its in the Esc.
aaugman is offline   Reply With Quote
Old 10-28-2010, 05:14 PM   #3
the lipo in the radio is fried
Old 10-28-2010, 05:19 PM   #4
hobbytown use to carry one i used in my m8 was like 20 bucks but i dont rember the brand and sold the radio like a year ago
redneck-john is offline   Reply With Quote
Old 10-29-2010, 05:02 AM   #5
hobbytown was no help still need help on this
thanks
Old 10-29-2010, 08:04 AM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You were using a 3 cell lipo? Did you not hear the alarm?
JohnRobHolmes is offline   Reply With Quote
Old 10-29-2010, 11:12 AM   #7
came back from crawling and left it in the truck. did not hear the alarm and fried a new thunder power lipo.
Old 10-29-2010, 11:37 AM   #8
Happens to the best of us. Hit up cheapbatterypacks.com, they can probably make you a replacement for pretty inexpensive. What size and type was your old pack?
Old 10-29-2010, 05:24 PM   #9
my pack was a thunder power 11.1v 2500 mah. it had only been charged twice i have a backup that i am using now from hong kong. just dont need to fry it to.
i have not been able to find any kind of cut off that will work.
with all u tech guy out there i was sure that someone had had this happen before and made a cutoff.
i know it is posible it comes in esc,s just not in a stand alone version
i just dont have the smarts to build it i can solder and follow directions
if someone can tell me what to buy and what to put where
or would be will to pay to have it built
thanks mike
Old 10-29-2010, 06:26 PM   #10
Even though ESCs have a cutoff, they will still drain the lipo all the same if the battery is left plugged into the rig with the power switch off. On a radio you can just turn off the switch instead of unplugging it and be safe. What I am getting at is that there is no auto shut off. You just have to remember to unplug the rig and turn off the radio.
Old 10-30-2010, 08:07 AM   #11
well shucks i thought there my be help for those of us that have c,r,s
guess i will just have to make sure i turn off the radio.
thanks johnrod
mike
Old 10-30-2010, 11:42 AM   #12
the only thing i can think of to help you remember to turn it off is rig up a bright LED on your transmitter that shows when its on so hopefully you see that better and remember ;)
dealwithit is offline   Reply With Quote
Old 10-30-2010, 04:16 PM   #13
i think that is what i will do put a bright red led on the front and a 75 dsbl horn on the vibrate wire.
so if you guys see a bright red light and hear a loud horn please remind me to turn off my radio.
thanks mike
Old 11-23-2010, 04:33 PM   #14
What do you meant by "fried?" If the lipo show really low voltage, you can bring it back to range by charging it as NiCad battery. Once in range, charge it as lipo. This only works with rx and tx batteries. Batteries to run the motor would be "gutless" afterward. Keep an eye on the battery while charging.
WARNING - do it at your own risk!
Kwarler is offline   Reply With Quote
