10-30-2010, 10:01 AM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Vancouver,Canada
| Tekin FXR wire size
I'm just finishing mine crawler got all pcs no and wondering if tekinfxr wire size#16 is ok to use becouse that what it came with. On pictures looks like other people use #14. I think since this is brushed the #16 is good enough i'm i right?Or why crawlers use # 14? Thanks for help |
10-30-2010, 10:21 AM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Well, if you can fit bigger.....then by all means do it, but in the end 16 will function. I use 13 awg with my FXRs.... Later EddieO |
10-30-2010, 10:29 AM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Some use 18. I use 12 or 14.
10-30-2010, 10:38 AM | #4 | |
Rock Crawler Join Date: May 2007 Location: Prescott
10-30-2010, 11:18 AM | #5 |
13 seems to be a nice balance. 12 is just too big and stiff.
10-30-2010, 11:24 AM | #6 |
but #16 wire must be sufficent becouse they suplly FXR combo with it right?
10-30-2010, 11:39 AM | #7 |
16 AWG is plenty big for a crawler. I run 18 awg, can't tell a difference in power. But smaller wire is a bunch lighter, more flexible, and much easier to solder. |
10-30-2010, 07:39 PM | #8 |
Newbie Join Date: Sep 2010 Location: New York
I used Deans 12ga ultra wire.
10-30-2010, 07:56 PM | #9 |
Pebble Pounder Join Date: Jun 2008 Location: PISCATAWAY
I just used 14ga novac on mine
10-30-2010, 09:03 PM | #10 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
x2 with manning. i'm using the supplied wire with my tekins |
11-01-2010, 09:15 AM | #11 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
16ga is PLENTY on a brushed crawler, I ran 16 and 18 and could not tell the difference in power. 12ga is not necessary, even 14ga is overkill really. |
11-01-2010, 01:37 PM | #12 |
11-01-2010, 02:07 PM | #13 |
11-01-2010, 04:26 PM | #14 |
Newbie Join Date: Sep 2010 Location: Toronto
13 gauge is the way to go or match your battery conductor size.
11-01-2010, 04:30 PM | #15 |
11-01-2010, 04:33 PM | #16 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
I run 20g with 400 puller's and thay pull twice the amps of 540 .
11-01-2010, 04:36 PM | #17 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
I used 12ga for a while then switched to 14. Its a bit easier it work with and makes your wiring a bit cleaner and its easier to solder the smaller gauge wires also. |
11-01-2010, 04:41 PM | #18 |
11-01-2010, 04:41 PM | #19 |
Quarry Creeper Join Date: Jun 2009 Location: Abbotsford BC Canada
14 from esc to punk dig (it's what i had kicking around) and 16 to the motors..I cant see a reason to use anything bigger than 16 really.
11-01-2010, 08:20 PM | #20 |
Quarry Creeper Join Date: Jul 2010 Location: Gila & Cibola
| My FXR came with wire that just says "Tekin Electronics" and it looks liked AWG 14 because i used some deans 16ga. for the motor. But yeah, like everyone said above, don't worry about the size being too small. That being said, i don't use anything smaller than 16. Heck the leads on the bec is tiny! |
