11-02-2010, 07:55 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: tacoma
| Dx3r dual fxr's
DX3R DUAL FXR'S NOVAK DIG I want the front to pull faster then the rear (get rid of stall in the front) whats the best way to do it i have the hot wire so i can plug it in to my lab top what do i mess with in the hot wire? |
11-02-2010, 09:49 PM | #2 |
RCC Addict Join Date: Mar 2008 Location: SSF
Change the front pinion, more tooth count. The Novak switch has no adjustability and I can't figure out what you can do to the ESCs. |
11-02-2010, 09:57 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
X2 more pinion teeth up frontMakes a world of difference.
11-02-2010, 10:03 PM | #4 |
doing that right now but still want more out of the front |
11-03-2010, 02:43 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
Gearing the axles different is about all you can do, we can't put timing on a motor through a brushed ESC.
11-03-2010, 03:33 PM | #6 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
If you still want more you NEED a 4 channel radio like the 4PL or the 4PKS end of story
11-03-2010, 06:24 PM | #7 |
thanks working on gettting one just have not worked for like a hole month so as soon as i get back to work i will be getting one |
11-03-2010, 06:49 PM | #8 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
If FXR's are being run you can run a more aggresive throttle curve in the front than the back, but pinion is best bet.
