11-05-2010, 11:05 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Fresno
| no light on punk dig?
so i had a chance to wire up my xr10 tekin fxr jr hv9100t castle bec spectrum sr300 w/ dx3r punk dig plugged in my battery tested steering --> ok tested and programed esc --> ok tested punk dig --> nothing, front and rear wheels still running and there is no light coming from the led on the punk dig this is my first time using a moa style crawler and first time using a dig switch any one know what i may have missed? or come across a similar problem? Last edited by NeXt559; 11-05-2010 at 11:09 PM. |
11-05-2010, 11:29 PM | #2 |
RCC Addict Join Date: Mar 2008 Location: SSF
Check to see if the Punk servo plug is plugged in correctly. Make sure the DX3R button you want to use for dig is selected. The Punk has a voltage limit, make sure your BEC is not set for 8.4v. How is your BEC wired? CC wiring or Alternate wiring? Is the SR300 used? I've seen the Aux channel fail, (I have three Spektrum Rxs with bad Aux channels). I think you could try plugging the Punk into the steering port on the Rx and see if it lights up. Eliminate variables. |
11-06-2010, 05:34 PM | #3 |
checked servo plug and it was a little loose replaced it and now the led glows red and only motor 1 responds. even after hitting the buttons dx3r buttons D and E are mapped as "aux 3p" epa's set at 100% bec is set to 6.0v bec is wired as described by cc aux channel checked by plugging servo into aux channel. *no problems works fine and hit all 3 positions dig plugged into channel 1 to test. only red light glows when wheel is turned left and right i also took a volt meter to the punk dig. power going to both motor1 leads and esc leads no power going to motor 2 anything else i might be missing? or do u guys think it's just a bad switch |
11-06-2010, 05:39 PM | #4 |
11-06-2010, 06:28 PM | #5 |
| aux sub trim set at 0 (zero) aux trim set at ???? (from what i know you can only adjust the sub trim and travel/ epa the on a dx3r) Last edited by NeXt559; 11-06-2010 at 07:29 PM. |
11-06-2010, 07:29 PM | #6 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
You check the framerate setting? Punks will not work on the 5.5ms setting. You may be set on this.
11-06-2010, 08:02 PM | #7 |
11-06-2010, 08:18 PM | #8 |
Make sure that your epa's are maxed out. Other than that I dont know, sounds like it may be defective. Should be green for 4wd, if none of that works try reversing your 3rd channel to see if the led switches to blue. If that works then it sounds like it has to be in your programing.
11-06-2010, 11:07 PM | #9 |
Yes, the only thing left to do is max out the EPAs just for the hell of it. Also, make sure your Aux expo isn't all whacked out. If it still doesn't work, it must be defective. |
11-07-2010, 04:50 AM | #10 | |
Pebble Pounder Join Date: Mar 2005 Location: England
Hi i had similar problems i read somewhere that only one button can be assigned 'aux 3p' at a time so having two assigned at the same time could be messing up the punk dig I havent got a punk dig anymore so i cant try it for you, but it may just be the problem Hope this helps heavyD | |
11-10-2010, 10:59 PM | #11 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Don't want to thread jack but does anyone know how to program the DX3R to work with a punk dig. I know i have to map the E button but I don't know how? Thanks in advance!!!
11-10-2010, 11:08 PM | #12 |
Push scroll button, scroll down to monitor, scroll down menu to button selection, select 3p. I think, it's been a while. |
11-10-2010, 11:14 PM | #13 |
I tried that but to no avail when I push in on the scroll button when it is on monitor and all i get is the monitor screen with no menu for button selection. Thanks
11-11-2010, 12:43 AM | #14 |
