11-10-2010, 05:29 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: East TN
| help?
ive got a supermate dc6 lipo charger but cant get it to work properly. im hopin to get some insight on what im doing wrong. im tryin to charge a 3s lipo but as soon as i push start it says "input vol err" which means "the voltage of input power drops below limit." what exactly does this mean. thanks
11-10-2010, 05:46 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Oregon
Im not familiar with that charger but it sounds like maybe your batt voltage has droped to low to charge. What is the Batt voltage for each cell?
11-10-2010, 05:54 PM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
11-10-2010, 05:58 PM | #4 |
says on the lipo max 4.2 per cell and max total is 12.6. confuses me because the battery says 11.1 on the other side (front). i have it hooked to a battery.
11-10-2010, 06:04 PM | #5 | |
The battery (guessing car battery) may need to be charged. Sounds like the voltage is going to low when you try to charge. You can also try charging at a lower amperage. 12.6 is what the pack will peak at. | |
11-10-2010, 06:30 PM | #6 |
thats what i was thinkin so i put the big battery on charge for a bit and it seems to be doing ok. fingers crossed. so when it gets to 12.6 i need to unplug it all or will it shut off? im assuming i have to set it to shut off at 12.6?
11-10-2010, 06:49 PM | #7 | |
It should shut off automatically as long as it is a lipo charger. | |
11-10-2010, 07:27 PM | #8 |
ok. thanks for the help.
