11-10-2010, 06:49 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: Columbus
| Suggestions for a Timberwolf
I recently purchased a rc4wd timberwolf chassis with trex axles and r2 trans and i'm wondering what size motor to use. I was planning on running brushed, unless that's a bad idea, and i plan on running it in all conditions: mud, rocks, water. I was also cosidering a Tekin FXR-pro esc and a i have a Hi-tec 7955Tg, will it have enough torque to turn this beast. I've tried searching on 3 different forums now and still can't get a straight answer.
11-10-2010, 07:17 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: summertown
sounds like you've got a Great ESC and a strong enough servo if you plan to stay brushed, i would check Holmeshobbies.com, or on here for a brood handwound personally i would get one of holmes's new sensored brushless motors |
11-11-2010, 07:06 AM | #3 |
| I thought a brushed setup would be better in the wet conditions though?
11-11-2010, 08:21 AM | #4 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
I would suggest a HH sport if your running through water. Brushes will wear out faster in. I consider a handwound a waste in a scaler, unless you have money to burn. Only brushless I know of is a VXL that is waterproof. I'd stay brushed. |
11-11-2010, 08:32 AM | #5 |
Quarry Creeper Join Date: Feb 2008 Location: Pittsburgh PA
Seems the majority of brushless motors are waterproof, ive had a few, including a castle 5700 fully submerged and it worked fine.
11-11-2010, 09:10 AM | #6 | |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
I'm running that in my Poison Spyder Tuber, which is very similar to the timberwolf; running a HH Sports 45 T and a Tekin FX-R ESC, my servo is an Hitec 7955TG and it has more than enough tourque for all situations. I run with Axial axles and and an Axial tranny, cause if had bad experience with the RC4WD Stuff. I've made all the axial stuff bullet-proof (Felsenfest knuckles, Felsenfest CVDs, HR alloy C's and in the rear a Felsenfest spool with Axial straight axles. Looks like this | |
11-11-2010, 09:59 AM | #7 | |
