11-10-2010, 08:54 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Monrovia
| am i damaging my servo, possibly esc?
Hi all, i've got an hpi crawler king with a tekin fxr and a hi-tech 7955tg the other day while crawling, the screw on the servo that attaches the steering link onto the horn broke, so i had to repair it out in the field. I didnt have a screw as thin as the one that was on there, so i had to use a body reamer to open the hole on the horn big enough to screw in a wider (m3x8mm i think) screw to continue...i don't know what measurement the original screw was... but now im wondering if that had anything to do with why my servo is now omitting a constant "thinking" buzz where as before it did that only under duress or just during normal steering and I know that buzz is normal but just sort of goes in and out when neutral, but now it's a constant buzz even when "letting go" of the steering and returning to neutral. sometimes when i adjust the steering trim a little or steer slightly left and right it goes back to the normal on/off buz...but if i turn the steering trim all the way left of right i get the constant buzz / it did not do this before / ..i can get the normal buzz if i play around with it like im trying to settle it back in a neutral spot by turning left/right, just btw, the trim is never in the center spot, wheels are always to the left side if the dial is in the center.. I ALSO when i tested it the next day, same thing, but i noticed that my fxr was pretty hot, not to the touch, but it was almoooossst having a faint smell, not like burning but shouldn't have had a smell only after running it for about 15 minutes in my house and just testing the steering so, my question is, is this maybe something with the digital servo not holding center or is something off that's causing the esc to heat up? am i damaging my servo gears bec it's under stress even when at a neutral point? im still kind of new to the game and am not sure if this can be solved by something i can program digitally with the 7955tg or something. or is it time to even consider replacing the stock tx ? any advice is most appreciated! thanks again in advance! |
11-11-2010, 03:08 PM | #2 |
Newbie Join Date: Apr 2010 Location: France
Hello , I can only guess but have you only reamed the horn hole ? If so that means the link before was already 3mm diameter . Admiting the screw was 2.5mm before it then had a some play movement so it could easily find a neutral point for the servo . But even so it shoudn't give much stress there , can you easily move the servo horn with you fingers ? (with batteries disconnected) The trim should only be used for fine adjustements only . When you put the horn on the servo the servo should be switched on and without any trim whatsoever so that it's in neutral position . Then you mount the horn so that the wheels looks as straight as posible (servo still on power holding it's neutral position) . The 7955tg gobbles 4.2amps @6.0v when lock/stall so I would think it's too much for the 3amps bec of the fx-r . |
11-11-2010, 03:26 PM | #3 |
Pebble Pounder Join Date: Nov 2009 Location: Bad Axe
My HiTec 7954 hums and buzzes all the time from the day it was new, I read somewhere that the HiTecs are noiser servos. I would agree that you are possibly now stalling out the servo, creating more heat in your ESC. I was stalling out my 7954 (didn't know it at the time) and it was overheating my Rooster Crawler ESC to the point it would shut itself off, without stalling my ESC would barely get room temp. |
11-11-2010, 08:12 PM | #4 | ||
I'll still have to play around with it more to get an optimal neutral point, plus i did end up upgrading the stock tx to at least a spektrum dx3e, (on a budget for now) so hopefully that'll help me get more accurate adjustments for the end points n such Last edited by inebriatedmarmoset; 11-11-2010 at 11:31 PM. | ||
11-12-2010, 07:51 PM | #5 | |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Your knuckles should move freely on the c-hubs when screw is tight. Did you accidentally lose the bushing that goes in between them? Its called a flange pipe and part# is ax30450 And your steering should move freely when disconected from servo. If not, find out where it's binding. Sounds like you have isolated it to the flange pipe listed above. Is it there? Or did you get loctite on the flange or knuckle that is freezing it up? Quote:
11-13-2010, 10:31 AM | #6 | |
11-14-2010, 01:20 AM | #7 | |
