11-11-2010, 08:07 PM | #1 |
Rock Stacker Join Date: Jun 2010 Location: tooele
| punk dig issues
alright here is my issue. green light on the punk dig all 4 wheels turn like they are suppose to. when i try locking up the front (blue light) everything works like it is suppose to but when i try locking up the rear (red light) all four wheels still turnany ideas? my specs are as follow tekin fxr Castle bec Spectrum dx3.0 with a sr300 reciever Punk dig |
11-11-2010, 08:36 PM | #2 |
Sounds like you need to get it fixed. I would call them and send it in.
11-11-2010, 08:54 PM | #3 |
sounds like a internal problem to you too
11-11-2010, 08:58 PM | #4 |
The DX3.0 only has a 2 position 3rd channel.
11-11-2010, 09:22 PM | #5 | |
Pebble Pounder Join Date: Nov 2010 Location: USA
Set up: Traxxas 2.4 remote traxxas vxl3s esc novak 55t venom dig unit w/venom servo any advice would be apreciated. | |
11-11-2010, 09:25 PM | #6 |
The red light is on right?
11-11-2010, 09:42 PM | #7 |
yeah i can get all three different colors to light up green is all wheels turning and then red is suppose to lock up one axle and blue is suppose to lock up the other axle
11-11-2010, 09:45 PM | #8 |
check to make sure your plugs are hooked into the reciever the correct way i tried switching mine around to see what is would do and when i switch my punk dig wires going to the reciever around that is what it did was flash green
11-11-2010, 09:46 PM | #9 |
If you mean the red light on the punk dig unit then yes and no. When the unit started changing light colors it ended on red light, but it didnt controll my dig what so ever and i still had full function on the truck just not the dig unit. I then turned the truck off then back on and it reverted back to fast blinking green light...im just totally confused. I sent punkrc an e-mail three days ago but still no response, then i called and he said he would call or e-mail me back but three days and still not headr from them.
11-11-2010, 09:48 PM | #10 |
Which wires did you switch around on the reciever? So do you actually have yours hooked up different from the instructions?
11-11-2010, 09:52 PM | #11 |
| i double checked my install and even made sure and watched the instructional video. After a while i did try to switch the reciever plugs a few times but no luck. Do you think you could post a picture of your wire install on the punk unit?
11-11-2010, 10:07 PM | #12 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
did you try reveresing the the two pos switch on the dx3.0
11-11-2010, 10:16 PM | #13 |
| There should be a decently loud click as the relays turn on and off. Are you hearing anything when changing from 4wd to rear dig? Compare what you hear when switching to front dig as rear dig. It sounds like the relay isnt firing. If you are getting the red LED to go on there should be no reason why it wouldnt work.
11-11-2010, 10:22 PM | #14 |
ya sorry i forgot to mention that part Whoops yes when it switches to blue you can hear the relay click over but no relay clicking over when the light switches to red
11-11-2010, 10:24 PM | #15 |
i dont know how to post pictures but they wires i switched around is the black red and white wires going from the punk dig switch to my reciever. so i turned the plug going into the reciever 180 degrees basically reversed the polarity
11-11-2010, 10:27 PM | #16 |
when i bought my punk he said it would work but i would only have front dig and no rear burn if you have it working one way try and reveser the switch and it should give you front dig |
11-11-2010, 10:29 PM | #17 |
plug it the same as you do all plugs and reveser the switch on the dx3.0
11-11-2010, 10:41 PM | #18 |
no i know what you are meaning with that i can get all three different lights like it is suppose to just not locking up the front axle ever but it does change the led color just no relay clicking which is why i believe it is something internal but just wanted to get more input before i sent it out to get fixed
11-11-2010, 11:08 PM | #19 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
I have seen some that where wedged between the upper links stop working.Just a thought. |
11-12-2010, 10:16 AM | #20 |
