11-13-2010, 07:14 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Gibraltar
| wiring CC BEC and using @ 7v, will it burn the RX?
i was wondering how would i need to wire the castle bec in order to supply my HS7980tg with 7v and still be able to supply 6v to the rx which has a working voltage of 5-6v max?? do any of you guys know how to get round this problem?? |
11-13-2010, 10:25 PM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
Here ya go I think this is what your looking for, Wiring it this way allows you to run 7 volts to your servo and let the esc power your rx... |
11-13-2010, 11:53 PM | #3 |
| Exactly. After switching to this from the wiring castle tells you to use I wont be going back. It makes much more sense this way.
12-21-2010, 09:36 AM | #4 |
thanx that as exactly what i needed |
12-21-2010, 10:18 AM | #5 |
Pebble Pounder Join Date: Dec 2010 Location: St. Lawrence County NY
The CC 10 amp BEC has brown, red and orange wires, which one is the signal wire? Orange?
12-21-2010, 10:31 AM | #6 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
12-21-2010, 10:35 AM | #7 |
12-21-2010, 11:39 AM | #8 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
I just made myself this out of a normal y harness and then just leave all 3 wires from the ESC and let it power the rx. Last edited by T3rry; 12-21-2010 at 11:41 AM. |
12-21-2010, 12:20 PM | #9 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
so 7v to the servo wont fry anthing? I run 6v to my JR9100t. I would love a bit more....but am scared of killing shit. |
12-21-2010, 12:39 PM | #10 |
| He has a HV servo, it'll actually take 8.4 volts as it's made to hook straight to 2s lipo. I run the same 7980 set at 8.4, my rx can handle the volts but the amp draw scared me so I use the harness style above. I've ran regular voltage JR's at up to 6.5 without issue, the gears were still the weak spot after a year and a half of beating.
12-21-2010, 12:42 PM | #11 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
12-21-2010, 12:54 PM | #12 |
| I also disconnect the signal wire from the BEC so you have the two power wires + & - from teh BEC and the Sig from the RX and leave all the wires intact where you plug in the srevo into the Y connector. This isolates the servo and bypasses the RX from the higher voltage.
12-21-2010, 01:41 PM | #13 | |
