11-14-2010, 02:05 PM | #1 |
Newbie Join Date: Sep 2010 Location: sacramento
| Futaba 3pks problem, need help
I got a futaba 3pks 2.4g and i seemed to be having problems with it. I keep losing the signal and can't figure out why? It will have signal and the receiver will have a green light then all of sudden i will lose signal and the led will turn red. I use to have a 3pm and never had any problems with it but when I switch to the 3pks it started. Oh and im using the same reciever I was using in the 3pm so I know the receiver is good and compatible. Batteries are all charged up too. |
11-14-2010, 03:00 PM | #2 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
Send it back to Futaba USA..... But first, you are using the same ESC/BEC and servo and stuff as before? I'm just thinking if you have add a new big baller servo, you might be running out of BEC amps. |
11-14-2010, 08:44 PM | #3 |
No i have the same setup as what I have on the 3pm the only difference is the radio
11-14-2010, 10:59 PM | #4 |
figured it out, i had to switch the setting from hrs to ppm and everything is running good
