11-14-2010, 04:30 PM | #1 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
| HS-225MG Genocide!
So as the title states Ive managed to kill a number of 225MG's(4) in a matter of days on my VP dig. The EPA's are correct for sure, Ive tried setting them super conservative w/the same fried results. I should state that I am burning up these servos within minutes of test driving on hardwood floor as I cycle through the dig. I tried powering the servos through a CC BEC at 6v as well as just using Rx power and same result. I have also overhauled my VP dig internals w/no luck. My radio is a KoPropo Eurus w/KR-408S also tried KR-407S. Any insight on my dilemma would be greatly appreciated. Here is a photo for those visual people |
11-14-2010, 04:58 PM | #2 |
i never have had luck with the stock pcb in those 225's i burnt mine up within a few mionutes as well but instead of buyin more i just take the pcb out of a standard servo and wire it in and no more problems
11-14-2010, 05:32 PM | #3 | |
Rock Crawler Join Date: Jun 2009 Location: summertown
what standard servo are you taking the pcb out of?? i've tried and couldn't get it to fit sorry about the Thread jack | |
11-14-2010, 06:08 PM | #4 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Only thing I can say is Futaba S3102, they are pretty much the same rating as the 225 but they are tiny AND I haven't burnt mine up. I have burnt up 225s but never my S3102 and I'm not easy on the poor little fellow. Kieren |
11-14-2010, 08:14 PM | #5 |
Your radio is burning them up, I use the KO EX-5UR and had the same issue with 85mg's. I paid a little more for a digital mini servo and was good for the next year until I switched to moa. All it took to burn the 85 mg's was to plug them in without a horn even installed, they would twitch and get hot until they burnt.
11-14-2010, 08:27 PM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Somewhere in 408
I've also had bad luck with these crappy servos (2) used with my R1 dig unit. The servos burn out in the first few minutes. I'm also using a KO Propo Eurus. Switched to a Hitec 625MG and so far no issue at all. |
11-14-2010, 08:36 PM | #7 | |||
11-14-2010, 08:45 PM | #8 |
well it can't just be the KO systems, because me and the wife run spektrum units (DX3R & E) and we have 4 dead 225's, one of which melted the board BTW: i've switched to the 85MG and have had no more issues. i think the 225 servo's are just SH*T! Last edited by Twisted Nuts; 11-14-2010 at 08:47 PM. |
11-14-2010, 08:50 PM | #9 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
wow i have used a 225 (plastic gear) on my losi all summer long at 7 volts with no problems on a dx3r
11-14-2010, 09:03 PM | #10 |
It's the speed of the system, 3r's let you adjust to a slower frame rate to stop the issue.
11-14-2010, 09:10 PM | #11 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
81mg FTW
11-15-2010, 12:44 PM | #12 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I cooked one of these myself and realized it had everything to do with the fail safe settings when using a spektrum setup. I purchased a new servo rebound, set the epas and have not had problem since. If the servo does not know where the true center is (failsafe setting) then it is hard to get a consistent EPA in my experience at least.
11-15-2010, 01:09 PM | #13 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
I used this servo too way back when I actually had a rig with dig on it (running an original VF dig). After setting the EPAs, never had an issue running it with my DX3r. It's always a bit hit and miss with the smaller servos though.
11-15-2010, 01:14 PM | #14 | |
