11-14-2004, 11:25 AM | #1 |
Newbie Join Date: Oct 2004
| Max voltage for a standard servo
My locale hobby store guy was telling me that because I am running dual servos for my 4ws I could run them off a 7.2volt pack. Is this true? My setup uses a Hitec 645MG in the rear and a 94358Z airtronics in the front, and a reversible Y connector to attach them both. I just want to make sure I would not be frying something. I tried the 6volt regulator that was discussed in http://www.rccrawler.com/postt3261.html but it didn't work well. seemed like there was too much draw for the battery. |
11-14-2004, 11:36 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: Max voltage for a standard servo
I've heard of guys using their 7.2V packs on here, I think Ace did for a while too.
11-15-2004, 12:29 PM | #3 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
I emailed Airtronics today to find out if it's ok to run my 94359Z on 7.2V. Dunno about the Hitecs. Jay |
11-16-2004, 06:53 AM | #4 |
Thanks for the help. I would figure the dual draw would help prevent them getting overloaded.
11-16-2004, 09:43 AM | #5 |
Overload how? Here's what I was mailed..... Jay: Can a 94359Z be powered at 7.2 volts without problem? Airtronics: No. Max 6 volts. Jay: Can the HS-645MG or HS-5645MG be safely operated at 7.2V? Hitec: Yes you would be able to. |
11-16-2004, 10:26 AM | #6 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
What about the reciever? Can it handle 7.2V as well?
11-16-2004, 10:37 AM | #7 | |
| Re: Max voltage for a standard servo Quote:
Jay | |
11-17-2004, 06:27 AM | #8 |
| Re: Max voltage for a standard servo You know I never thought about the reciever getting fried. I might want to look into that.
11-17-2004, 07:15 PM | #9 |
Quarry Creeper Join Date: Aug 2004 Location: HP lounge
How about a 4 cell 3000mAh pack? That'd be at least 5v or so, and would last forever. Maybe I'll tear up another cheapo pack and make a couple 5 cells.
11-17-2004, 08:16 PM | #10 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Couldnt you just bypass the reciever and Y harness the batt in like your forced to do on 1/4 scale servos? I'll give it a try with the 645Mg's if my clod ever runs again |
