11-16-2010, 01:49 PM | #1 |
Pebble Pounder Join Date: Jul 2009 Location: CO
| crab walk , four wheel steer, and dig???
is it possible to make a rig crab walk four steer (dependent and independent) and dig all with the confine of a pistol style remote?? Does any one know if this is possible? what is need to do this can some me where these component can be had. |
11-16-2010, 01:57 PM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
Futaba 4pks.
11-16-2010, 02:49 PM | #3 |
11-16-2010, 03:20 PM | #4 |
Yea i have a radio i just built that can handle all of this. I left out the independent rear steer but i can easily add it on. here is the semi build thread, turned into a picture and vid thread because i had some major quality control problems i had to deal with from the stick radio i used. The ULTIMATE radio for crawlers, including the new XR-10 Last edited by Grizzly4x4; 11-16-2010 at 03:37 PM. Reason: nope |
11-16-2010, 05:01 PM | #5 |
i suppose i should have probably said this would like me on a MOA application?? Does change anything at all?? Also how critical is dig when you have 4 wheel steering (independt / dependent) |
11-16-2010, 05:04 PM | #6 |
i don't have 4ws on my crawler so i don't know. But i think dpendent would be fine.
11-16-2010, 05:34 PM | #7 | |
or Do you want one ESC to control both motors, have a separate dig switch, and independent 4ws? This is how my super is set up. Dig is always helpful, even with 4ws but not critical. | |
11-16-2010, 05:53 PM | #8 | |
11-16-2010, 06:07 PM | #9 | |
My setup the rear steer is manual and completely separate from the front steering. For that you only need a 4ch radio with 3 position switches on ch3 and ch4. Something like this would work but look over the features carefully, like no endpoint adjustments on ch3 or ch4. That can be worked around though.: http://store.rc4wd.com/RC4WD-XR4-4-C...ver_p_676.html | |
11-16-2010, 06:51 PM | #10 |
Quarry Creeper Join Date: Jan 2010 Location: USA
The Futaba 3PL may be another choice for you. It has steering mix built in (4-wheel and crab only) on the +1 channel (CH4). You can modify CH3 to be 3-positions as well. Check it out in this thread: http://www.rccrawler.com/forum/showthread.php?t=278219 |
11-16-2010, 06:58 PM | #11 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
I was using the Nomadio Sensor with a single BRXL esc, punk dig, on super bully's (moa axles) and also had 4ws and crab walk. The only thing you REALLY need to do to switch from crab walk to 4ws is reverse the rear servo and you can set up the remote to do that just by pushing one soft key.
