11-18-2010, 02:52 AM | #1 |
Rock Stacker Join Date: Oct 2006 Location: Mandeville, Louisiana
| setup + this battery...safe?
im new to LiPo batteries so bear with me. battery i would like: http://www.maxamps.com/Lipo-1800-74-Pack.htm electronics: CC sidewinder, novak 55t, CC BEC, Hitec 645mg im open to suggestions. im looking into lipo because apparently theres a very large run-time with them? about how much run time would i get out of this? |
11-18-2010, 03:00 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Is it going in a honcho like in your sig? I would go with a 3s or 4s pack if you already have the 55t |
11-18-2010, 06:32 AM | #3 |
Runtime depends on a lot more factors such as terrain, gearing, driving style, etc. Generally in an Axial AX or SCX maybe you could get up to an hour but remember that your runtime may vary and can be significantly lower. However, continuous running isn't very good for the motor and your ESC will get warmer too. |
11-18-2010, 06:43 AM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Run time is run time regardless of the battery type. Terrain and throttle application are more determining factors. What you get with Lipo is consistent run time, that is, the same power from start to finish. So if you're looking for more run time go with a higher mAH rating and enjoy both. Also, I'd agree that a 3s pack will serve you better with a 55T motor. In my humble opinion spend your money elsewhere for a Lipo; MA is overpriced and underpowered. Read this and then contact Chris about a battery...more than likely you'll be able to get a higher mAH pack from CBP for the same price as the one you're looking at from MA. While testing Elite against others we found big C Rating trickery Last edited by CreepyCrawl; 11-18-2010 at 06:46 AM. |
11-18-2010, 03:05 PM | #5 |
well i have a 4500 MAH from CBP already. its just i keep hearing about how awesome Lipo batteries are and how people can sometimes get like 2 hours of run time out of them. back when i only had a venom 1800 on my wheely king i could get like 15-20 minutes out of it. i know id be fine with the 4500 i have but i was just trying to scratch the surface of lipo batteries. perhaps ill save the money and put it elsewhere on the truck and stick with this mAH battery because that would mean buying a new charger as well...
11-18-2010, 03:11 PM | #6 |
get a 35t motor, that 55t will be a turd in the scx
11-18-2010, 03:26 PM | #7 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
Agreed. Even a cheap 35T will increase the "fun factor" without losing any noticeable low end control. 3S will give it a nice kick in the butt for all-around bashing and burning up the trails, hill climbs or smokin' the rocks . A 7 cell nickel metal pack ain't bad either, if you don't have a lipo charger.
11-18-2010, 03:29 PM | #8 | |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Give em call I'll get you what you want....... better yet what you really need. 888-654-4450 Jason | |
11-18-2010, 04:44 PM | #9 |
this sounds good. ill try to get in touch with ya jason sometime by next week. but i dont run full throttle. im a crawler. i only use the wheel speed when i have to and dont feel like using a winch. however the only reason i liked the 55t turn is for the smoothness during lowend and precise movement. if i can have that and still gain some wheel speed ill go for that. maybe a tekin hand wound 35t or something. |
11-18-2010, 04:49 PM | #10 | |
damn smooth low end, killer tourqe, and great top speed. ive bent 2 front cv axle shaft pins, broke 2 C-hubs, and broke 2 kuncles because of mine! im running a sidewinder, HH 30t, and a hi-tec 645 steering servo all on a 1300mah 2s lipo 30-45 min of run time usualy, LOVE IT! Last edited by 2500hdon37s; 11-18-2010 at 04:53 PM. | |
