11-18-2010, 01:28 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
| 7T Cobalt motor
Thinking of trying these motors in my 2.2 comp rigs: Very powerful Cobalt DC motor. It is an 05 class motor. Comparable in power to a 25-30 class glow engine. This motor is an OEM item, and is new, without retail box. The motor comes with a Deans connector installed. The output shaft has also been OEM modified with a flat machined the length of the exposed shaft. This will aid greatly in securing hub set screws to the shaft.Peak watts with 12 cells @ 35amps is 504 watts! SPECIFICATIONS PROMAX 1507 Winding 7 Wire Gauge 20 Length, in 2.55 Diameter, in 1.32 Weight, oz 6.5 Shaft Dia., in 5/32 Max # of cells 12 Max Current 35 Typical # of cells 7-10 Test prop . 7x6 Test Voltage 8.5 Static RPM 12,500 Static Amps 27.5 Static power, Watts 234 Static thrust, ozs 32 Motor Constants KV (rpm/volt) 1834 Rm, Ohm .049 Io, neutral no load current 3.0 Comments anyone?? Narly1 |
11-18-2010, 01:31 PM | #2 |
In what truck? I run a similar motor in my Ax10 based rock racer and it is a LOT of fun! Plenty of torque and wheelspeed. These motors are parts breakers! |
11-18-2010, 01:37 PM | #3 | |
Narly1's FF-4 build Narly1 | |
11-18-2010, 01:49 PM | #4 |
You might want to verify that the motor will fit in the FF4.....IIRC, those motors are around 2.5" in length (from mounting surface to endbell)...
11-18-2010, 01:57 PM | #5 |
11-18-2010, 02:04 PM | #6 |
Pebble Pounder Join Date: Apr 2010 Location: Olympia
if it will fit how can you beet the deal for only $40. I am looking at buying one now |
11-18-2010, 02:11 PM | #7 |
Awwwwh crap! According to post #12 in Underground Crawlers FF-4 "Frame Forward" Chassis she's no a gonna fit. File 13 that idea, LOL! Narly1 |
11-18-2010, 02:39 PM | #8 |
Rock Crawler Join Date: May 2009 Location: 354
wow, I want that motor, question thou. Would that fit an SCX10 based truck?
11-18-2010, 04:37 PM | #9 |
11-18-2010, 04:50 PM | #10 |
Shaft diameter is 4mm of the motor, but otherwise they are hoss.
11-18-2010, 06:08 PM | #11 |
11-18-2010, 06:18 PM | #12 |
no 1/8in is about 3.18mm not almost 5mm so they are larger tan standard any if says the shaft diameter is 5/32"
11-18-2010, 06:26 PM | #13 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
I have this motor and it is a beast |
11-18-2010, 06:38 PM | #14 | |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
as for the shaft size you will have to bore out a standard pinion or find a supplier of 4mm bore pinions that are the correct pitch i have a holmes 7 and a 10..both killer motors | |
11-18-2010, 07:18 PM | #15 |
11-18-2010, 07:26 PM | #16 |
Quarry Creeper Join Date: Aug 2008 Location: Orange City
Anyone know of any suppliers for 4mm pinions?
11-18-2010, 08:53 PM | #17 |
Decided to buy a couple to play with...... Will likely have the exposed part of the armature shaft turned down to 1/8" so I can use standard pinions. Narly1 |
11-19-2010, 05:20 AM | #18 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
I'm sure going to pick one up at that price. Run it when I know I'm not going to get wet.
11-19-2010, 07:56 AM | #19 |
| When I was looking at similar motors in the past (Astroflight pullers), I did not find any. I did think of trying to use something like tin foil around the 4mm shaft and then putting a 5mm ID pinion on there....but never actually tried this.
11-19-2010, 08:24 AM | #20 |
do you guys have a link as to where I can order, sorry i'm a computer dummy |
