11-19-2010, 07:37 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| 7950 vs. 7980
Is it worth the extra money for the 7980? It will be going in a xr-10 if that makes a difference. Also where is the cheapest place to get them? Thanks for the help |
11-19-2010, 11:26 PM | #2 |
Does anyone have any opinions? I;m hoping to buy one tomorrow. Thanks |
11-19-2010, 11:30 PM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
7950 works great dont know about the 7980 but i dont think it could hurt
11-19-2010, 11:37 PM | #4 |
Do you ever feel as you would like the extra 150 ish onces of torque? Thanks |
11-19-2010, 11:38 PM | #5 |
Rock Crawler Join Date: Apr 2009 Location: bend
| servo
i have two 2.2 crawlers i like the hobbico 170, 333 oz torque works great and less than 100 bucks
11-19-2010, 11:46 PM | #6 |
11-19-2010, 11:48 PM | #7 | |
Thanks | |
11-20-2010, 12:02 AM | #8 |
11-20-2010, 10:03 AM | #9 |
Quarry Creeper Join Date: Jan 2010 Location: GV
I disagree, I see no disadvantage to having more power, I have no idea where this whole " too much servo" idea came from, I have ran or driven everything from a 645 to the 7980 on my truck and the power is nice in a comp truck, my rig is only comped, and the 7950 is weak for my liking. For as little cash as it takes to step up and as easy it is to bolt it into an xr I say go for the 7980
11-20-2010, 10:31 AM | #10 | |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
11-20-2010, 12:01 PM | #11 | |
Rock Crawler Join Date: Mar 2004 Location: Albany
The problem about going over board on a servo is that bigger isn't always better. With that much torque if you slip or your rig twitches it can and on a light weight rig under 6lbs most times reposition the rig completely. I personally wont run anything higher then mid 400's because I don't need it and rarely bind it that bad to want to put that stress on the servo. Another thing to watch is how much weight is up front verse the rear as this will drastically change how bad the rear shifts when you steer. | |
11-20-2010, 12:41 PM | #12 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
You also have to think about the type of terrain you'll be running on. Some places have a lot of tire pinching rocks and holes where you might like having that extra torque to redirect your tires out of a sticky situation. If you can pay for it, get the higher torque servo...
11-20-2010, 12:53 PM | #13 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
The 7980 is also larger and on a xr10 the tire gets real close to the servo. I personally ran a 7950 on 7.2 volts on my berg and that was enough power to turn my super tires. I now run a 7950 on my 2.2 and it has plenty of power for every comp situation. You also got to think about high volt servos with the small lipos we run whitch can shorten run time.
11-20-2010, 03:29 PM | #14 |
So it sounds like the opinions are split. Were would be the cheapest place to find a 7980, since it seems to come down to price. Thanks |
11-20-2010, 04:18 PM | #15 |
Don't forget the xr10 servo mount kinda sucks bc it allows servo contact wth the front right tire so u might want the smaller servo. I think some one else mentioned it but it seams like you might have missed it |
11-21-2010, 12:00 AM | #16 |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
I have been using the 7950 for quite a while with no issues and i am very hard on rigs.. The 7980 is also a great servo, but larger in size and slower.
11-21-2010, 08:46 AM | #17 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I love my 7980....I'm not sure I can go back to a smaller servo after running this beast...if it's going on a xr10 I think that's good reason to get the 7980...less likely to bind up with the servo hanging out there when you have the power the 7980 has.
11-21-2010, 09:35 AM | #18 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
I have two bergs one with a 7980 and the other has has a 7950. For the bulk of people out their I would recomend the 7950. One it has plenty of power especially if you use a BEC, and the case will fit with no modifications. The 7980 is a monster I run it on my V2axled berg with a bec. The rig weigs in at 6.1 LBS, I have it set up in a 86jeep style steering set up. This servo has the power to literally move the whole rig. I have literally bent 2 tierods in binds. The thing is a monster! THe big thing is it is over kill for most rigs, not to mention if your not the type to modify things on your own you might stop right there as your going to have to move the servo mounting holes to compensate for the larger footprint of the 7980. |
11-22-2010, 12:54 PM | #19 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
7980 is unnecessary for the XR10 unless you're building up an 8 pound rig I've been beating the hell out of 7955 on my XR and a 7950 is exactly what you need |
11-22-2010, 02:15 PM | #20 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
what voltage are you guys running your 7950 at i got mine today
